Dual Extrusion Offset November 16, 2013 03:02PM |
Re: Dual Extrusion Offset November 19, 2013 01:34AM |
Re: Dual Extrusion Offset November 24, 2013 03:45AM |
Re: Dual Extrusion Offset November 24, 2013 06:27AM |
Re: Dual Extrusion Offset November 24, 2013 12:02PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Dual Extrusion Offset November 24, 2013 01:18PM |
Re: Dual Extrusion Offset November 24, 2013 02:38PM |
Re: Dual Extrusion Offset November 24, 2013 02:40PM |
Sublime
Marlin says it is M218 [github.com]
But the RepRap wiki says it is G10 [reprap.org]
In my old version of Marlin it does not have either.
So maybe you can use one of them and maybe you can not. I think you will need to know more about your firmware to figure it out.
Re: Dual Extrusion Offset November 24, 2013 02:58PM |
justcurious
It is not a good praxis to ask for help without delivering proper documentation for your setup as a start so forum has a chance to locate your actual problem. Different combinations of hw / fw / hosts have different opportunities.
You should at least inform of host sw, firmware/version and slicer used and maybe files used for test in stead of just indicating slic3r has some bad issues (which I assume you are indicating).
Re: Dual Extrusion Offset November 24, 2013 03:16PM |
Re: Dual Extrusion Offset November 24, 2013 03:27PM |
Re: Dual Extrusion Offset November 24, 2013 04:03PM |
Re: Dual Extrusion Offset November 24, 2013 05:38PM |
justcurious
re Aberrant
Ok that gave some sense, but I do not have the final clue despite of this. Some confusion adds because your offset problem changes down this issue dialog :-(
Marlin use M218 for extruder offset as you have experienced, G9-10 is used for retraction purpose.
If enabled you may check EEprom settings for homing offsets just to verify.
Wonder why you need 2 homing sequences rel and abs position in prefix code?
Re: Dual Extrusion Offset November 24, 2013 11:35PM |
Re: Dual Extrusion Offset November 25, 2013 01:54AM |
Re: Dual Extrusion Offset November 25, 2013 03:13AM |
HarveyC
Centering the print on the bed ... that brought back some memories to me, and I have just looked up my notes.
I too had problems with getting the print centered on the bed, and in the end, in spite of what I said earlier, I did not set my primary nozzle to 'all zeros' in the G10 command, but set the G10 command so that the object was printed centrally on the bed, I then set the offsets on the other nozzles to match. I remember finding it very difficult to get my head around how all this worked, and in the end I used a spread sheet to record the parameter changes and their effect. I used a very simple thin object to do the print tests, so that the job ran quickly.
Don't forget that in Slic3r the bed size is only used to effect the representation of the objects on the image of the platter, it does not effect the actual position of the object on the printer bed.
Harvey
Re: Dual Extrusion Offset November 25, 2013 03:23AM |
Re: Dual Extrusion Offset November 25, 2013 03:28AM |
Sublime
Is it possible instead of:
M218 T1 X56.5 Y0.0; which has centre on T0 with the offset on T1
You need:
M218 T0 X-56.5 Y0.0; which would put the centre to T1 with the offset on T0
or
M218 T0 X-28.25 Y0.0; with this the centre would be in between the nozzles
M218 T1 X28.25 Y0.0; with this the centre would be in between the nozzles
Re: Dual Extrusion Offset November 25, 2013 01:01PM |
Re: Dual Extrusion Offset November 25, 2013 01:26PM |
Re: Dual Extrusion Offset November 26, 2013 01:49AM |
HarveyC
You need to set the offsets with a G10 command not M218. The format of the G10 command is:-
G10 Pn Xn Yn Zn
Where:-
P is the number of the extruder (1st extruder is P0)
X is the x offset for this extruder
Y is the Y offset fopr this extruder
Z is the z offset, but (at least on my Reprap Pro Medel Tricolour) this is normally set to 0 as the z offset is set by the z limit switch.
Set your first extruder to all zeros (i.e G10 P0 X0 Y0 Z0)
then set the second one so that it prints in the correct place in relation to the first.
Don't forget to save the setting in firmware with M500 aftwerwards.
There is a very good description of this process at [www.reprappro.com]
Hope this helps
Harvey
Re: Dual Extrusion Offset November 26, 2013 01:56AM |
justcurious
You are probably assuming the leftmost extruder is E0?
Try to switch your assumption and exchange M218 commands so that rightmost extruder is E0 (T0) and offset is set to left most extruder E1 (T1).
I do not think it is fair you are consulting all community forums about this the same issue at same time and demand attention from a lot of people without learning anything particular and without giving feedback of your own testing .
Re: Dual Extrusion Offset November 26, 2013 02:13AM |
Sharing Results November 30, 2013 02:41PM |
T0_Neg_56.5 November 30, 2013 03:10PM |
T1_Pos_56.5 November 30, 2013 03:13PM |
T0_Neg_56.5_T1_0.0 November 30, 2013 03:16PM |
T1_Pos_56.5_T0_0.0 November 30, 2013 03:18PM |
Re: Sharing Results November 30, 2013 03:20PM |
Results_Comparison November 30, 2013 03:53PM |
