Re: Help, internal size of part(s) too small... December 20, 2013 08:16PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Help, internal size of part(s) too small... December 21, 2013 04:45PM |
Re: Help, internal size of part(s) too small... December 21, 2013 04:59PM |
Re: Help, internal size of part(s) too small... December 21, 2013 06:27PM |
Qsilver
Ok, Since I started this thread, I have not gotten any answers..
More questions yes, but answer no...
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Help, internal size of part(s) too small... December 21, 2013 11:30PM |
Re: Help, internal size of part(s) too small... December 22, 2013 04:59PM |
Re: Help, internal size of part(s) too small... December 23, 2013 08:42PM |
Re: Help, internal size of part(s) too small... December 23, 2013 09:02PM |
Re: Help, internal size of part(s) too small... December 23, 2013 11:09PM |
Re: Help, internal size of part(s) too small... December 24, 2013 07:20AM |
Re: Help, internal size of part(s) too small... December 24, 2013 12:48PM |
nophead
Not sure why you think it should be making correct parts when you have shown the volume dispensed makes a track 0.4537 wide but only offsets by 0.4/2.
nophead
Actually... (snip) ..The error between intended width and actual width is only the layer height times (1-pi/4) which is 0.043mm for 0.2mm layers. .....
Re: Help, internal size of part(s) too small... December 24, 2013 01:15PM |
Re: Help, internal size of part(s) too small... December 24, 2013 01:30PM |
Re: Help, internal size of part(s) too small... December 24, 2013 02:31PM |
nophead
I am wondering if multiple outlines actually gives a bigger error because the plastic doesn't want to flow right into the sharp corner under the rounded edge of the previous line. If it leaves an air gap there then each subsequent outline will give an bigger error, which seems to be what I observe.
Re: Help, internal size of part(s) too small... December 24, 2013 03:05PM |
Re: Help, internal size of part(s) too small... December 24, 2013 03:28PM |
Re: Help, internal size of part(s) too small... December 24, 2013 03:36PM |
Re: Help, internal size of part(s) too small... December 25, 2013 04:26PM |
Re: Help, internal size of part(s) too small... December 25, 2013 06:15PM |
Re: Help, internal size of part(s) too small... December 25, 2013 10:16PM |
nophead
There is also the mystery that Sublime claims to get perfect sizes from Kisslicer but I don't.
nophead
Cura is primarily written for Bowden machines, so some things are not right for non Bowden. For example it likes to miss out retractions whereas I like to always have them as they work properly on non-Bowden.
Re: Help, internal size of part(s) too small... December 26, 2013 09:17PM |
I believe that CuraEngine has recently been refactored now so that the code is more conventional (only declarations in the header files).Quote
nophead
I intend to fork Cura and fix it because I like its simplicity and it is written in C++, albeit with a bizarre form where everything is in .h files.
Re: Help, internal size of part(s) too small... December 26, 2013 09:42PM |
Sublime
@ Greg Frost
I wrote a quick script that lets you reduce the flow rate of the perimeters like you would with skeinforge but works with Cura and Kisslicer if you would like to try it out. [github.com] . It allows you to adjust any extrusion types flow rate using Marlins M221 flow rate modifier and has Nopheads flow rate equation in it for the perimeters so all you have to do is enter the layer height and extrusion width in it before processing the gcode file.
Re: Help, internal size of part(s) too small... December 26, 2013 10:07PM |
Greg Frost
Sublime
@ Greg Frost
Reducing the flow is not always what you want. Look at the following two pictures. One was done using a reduced flow such that the part came out "right-sized" and the other was done using an increased inset so that the part was "right-sized".
You can see that the outer perimeter on one of them hasnt always bonded well with the layer below. The one with consistent flow but increased inset has bonded well.
Re: Help, internal size of part(s) too small... December 27, 2013 12:12AM |
Re: Help, internal size of part(s) too small... December 27, 2013 06:07AM |
Greg Frost
nophead
What would be the principal difference in the ground up slicer you would write. What language would you use?
The key things I would like in a slicer:
Infill every n layers/skin.
Control over perimeter inset (with a sensible default based on the rounded extrudate maths)
Independent flow rate/speed settings for bridges (including dealing with the bridge being a different thickness to the rest of the model's layers).
Speed setting for top layers
Filling small gaps.
Some advanced things I think would be good:
Dealing with the fill from different directions to avoid the ridge (reduced volume runs)
Some canonical tuning models built in (e.g. Slice a bridge test model so that it uses a progressive range of speeds or flows so that the optimum settings can be determined relatively easily, another eg: a model that tests dimensional accuracy by printing a press fit joint. Another eg. A model that tests for backlash).
Re: Help, internal size of part(s) too small... December 28, 2013 06:52PM |
Re: Help, internal size of part(s) too small... December 28, 2013 10:20PM |
Re: Help, internal size of part(s) too small... January 02, 2014 02:23PM |
Re: Help, internal size of part(s) too small... January 02, 2014 02:58PM |
Re: Help, internal size of part(s) too small... January 02, 2014 06:36PM |
