Gaps between perimeter and infill January 13, 2014 01:48PM |
Re: Gaps between perimeter and infill January 13, 2014 05:06PM |
Re: Gaps between perimeter and infill January 14, 2014 04:06AM |
Re: Gaps between perimeter and infill January 14, 2014 04:34AM |
itaysp
Hello,
I get gaps in many slices, I thought it's something with my printer but then I looked at the gcode simulator of repetier and I saw it's actually the slicing.
Is it some setting I'm doing wrong?
Attached a photo
***I'm using the latest RC2 version.
Re: Gaps between perimeter and infill January 14, 2014 05:04AM |
Re: Gaps between perimeter and infill January 14, 2014 05:58AM |
itaysp
Hey, thanks for you responce.
1. The object should be hollow, so I must have 0 infill, but first few layers are solid.
2.I set it to 140% at the "Advanced" tab to check if it solves the problem. when I set it to 0, the same happens (slic3er makes the calculations)
3. the same as 2.
4. My exturer steps/mm are not correct to instead of changing it in the firmware I changed in slic3r. I followed this tutorial.
And i'm attaching a photo of all the "Advanced" tab are 0 (slic3r makes all calculations)
Re: Gaps between perimeter and infill January 14, 2014 06:25AM |
Re: Gaps between perimeter and infill January 15, 2014 02:06PM |
Re: Gaps between perimeter and infill January 20, 2014 04:45AM |
Re: Gaps between perimeter and infill January 27, 2014 10:17PM |
Re: Gaps between perimeter and infill January 28, 2014 08:51AM |
Re: Gaps between perimeter and infill January 29, 2014 10:34AM |
Re: Gaps between perimeter and infill January 30, 2014 10:47AM |
