Hi there, ive just finished building my first printer, the prusa i3. The printers all good to go, for the calibration cube i converted an stl. into gcode using slic3r however as i go to run the file in pronterface the extruder temp, which in sic3r settings i set to 240 gets set to 200 after running the gcode, the printer waits for the extruder to reach this temp and then start printing however the plastic doesnt extrude very smoothly due to the lower temp. I have the same problem with the heatbed
Im running sprinter through an arduino/ramps setup.
Thermistors are all working and i can manually reach 240 and extrude (ABS) smoothly.
Ive included an image of the slic3r setting and feel that the problem lies in the sprinter firmware (the section of which is in the image).
Edited 1 time(s). Last edit at 01/25/2014 03:19PM by AdeelUK.
open |
download -
(155.3 KB)
