Slic3r 1.0.0.0 Bug
Posted by KimBrown
Slic3r 1.0.0.0 Bug
April 17, 2014 06:13PM
Please could the bug that resets the skirt level to two each time be sorted.... It is annoying.
Thanks for the Hard work making Slic3r so good....
Kim
Edited 1 time(s). Last edit at 04/17/2014 06:18PM by KimBrown.
Re: Slic3r 1.0.0.0 Bug
April 19, 2014 02:23AM
You should put this in the proper place for bugs and requests on GitHub, the author rarely visits here and would have no way to track issues unless properly documented.
Edit to add:
Looks like you could set it in the ini file manually (in text editor) see the example of part of the file
retract_speed = 30
rotate = 0
scale = 1
skirt_distance = 2 <----------
skirt_height = 1 <----------
skirts = 2 <----------
slowdown_below_layer_time = 15
small_perimeter_speed = 60
Edited 1 time(s). Last edit at 04/19/2014 02:28AM by tmorris9.
April 28, 2014 06:50AM
Could you please test whether this happens with 1.1.1 too?
