1st layer issue March 26, 2018 11:38AM |
Re: 1st layer issue March 26, 2018 06:17PM |
Re: 1st layer issue March 26, 2018 09:02PM |
Re: 1st layer issue March 27, 2018 04:03AM |
Re: 1st layer issue March 27, 2018 04:55AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: 1st layer issue March 27, 2018 06:43AM |
Re: 1st layer issue March 27, 2018 10:41AM |
Re: 1st layer issue March 27, 2018 11:50AM |
Re: 1st layer issue March 27, 2018 12:52PM |
Re: 1st layer issue March 27, 2018 05:37PM |
the_digital_dentist
I've never understood why slicer sets layer heights using a %, and reporting a % here is meaningless without knowing a % of what.
Well, if one changes the layer height from 0.2 to 0.3, using % for first layer or whatever would negate having to change many items instead of just 1. But then YMMV.
I always set specific mm values for both layer thicknesses and line widths. It's too easy to make an error when you use percentages. I also use volumetric extrusion, leave the extrusion multiplier set to 100%, and set filament diameter to the calculated mean of 20-30 measured values.
I guess it might be time to understand what Volumetric Extrusion is
And calibrate the snot out of the extruder!
Are you using autoleveling? With a flat plate on 3 screws it should be unnecessary.
I am using 3 point - it only compensates for any tilt. But I tweaked it down to those numbers so it is pretty level as it stands.
The last print looks way better when it came off the bed. Maybe it is a "feature" of the PEI.
Re: 1st layer issue March 27, 2018 05:42PM |
o_lampe
The infill starts, where the perimeter ends. That depends on the position of the part relative to the bed coords.
I was not referring to the infill. The last pic shows it printing FROM the corner it was printing TOWARD to finish the 1st layer.
It just stopped printing TOWARD the corner and restarted at the corner back to where it stopped.
BTW: looks much better now. If you need a perfect surface, acetone can smooth out a lot of crinkles or a thick layer of paint would do, too.
I don't need it perfect, just trying to understand what it is doing.
Re: 1st layer issue March 28, 2018 11:04AM |
ruggb
the_digital_dentist
