Support for tall thin object
Posted by Pinzgauer
November 30, 2018 02:08PM
Hello,
In my attempt to print a 200 mm aerofoil on end (tall thin print), it has become clear that supports are needed. An example of the kind of support I would like to use is attached except that my object is an aerofoil rather than a stylus as in the picture. Some have suggested laying the aerofoil down flat or putting a long narrow edge down on the print bed but those options also have drawbacks.
Can adding the cylindrical supports be done in Slic3r? If not, can you suggest software to manipulate an .STL file to add supports before slicing?
Kindly,
Michael
open | download - Support Column for Tall Thin.jpg (803.4 KB)
Re: Support for tall thin object
November 30, 2018 09:54PM
Why don't you put the supports into the CAD file before you export the stl file for printing?
Son of MegaMax 3D printer: [www.instructables.com]
December 01, 2018 06:19AM
Pinzgauer
You could use Meshmixer. Video: [www.youtube.com]
December 02, 2018 03:58AM
This airfoil is 260mm high and it prints reliable without support.
I simply used a wide brim on LokBuild print surface and made sure the nozzle didn't scratch on the latest layer. ( minimal underextrusion of 95% )
