nb99 Wrote:
> Is there a way to duplicate 1 or more items loaded
> onto the grid in the Object Placement screen?
> If I load and arrange say 4 small items, then I
> want to have that row of items 3 more times on the
> grid, being able to select, then Ctrl-C + Ctrl-V
> to copy and paste would be cool.
> ATM I seem to have to use the Add STL dialogue for
> each individual added item.
Currently this is not supported, but it will come. It will also include a auto place function, so you can even copy several marked objects and fill the bed.
> Also - intermittently, when adding STLs, the
> Object Placement screen switches to a seemingly
> random viewpoint - is this controllable, can I fix
> it at top-View?
The problem is the closing file dialog. If it lies above the graphic, the click is also registered here causing the change. I will see if I find a trick to prevent this.
Visit us on
Facebook and
Twitter!
