making copies in object placement
March 16, 2012 08:51PM
Is there a way to duplicate 1 or more items loaded onto the grid in the Object Placement screen?
If I load and arrange say 4 small items, then I want to have that row of items 3 more times on the grid, being able to select, then Ctrl-C + Ctrl-V to copy and paste would be cool.
ATM I seem to have to use the Add STL dialogue for each individual added item.
Also - intermittently, when adding STLs, the Object Placement screen switches to a seemingly random viewpoint - is this controllable, can I fix it at top-View?
Edited 1 time(s). Last edit at 03/16/2012 09:09PM by nb99.
Re: making copies in object placement
March 17, 2012 04:10AM
Currently this is not supported, but it will come. It will also include a auto place function, so you can even copy several marked objects and fill the bed.
> it at top-View?
The problem is the closing file dialog. If it lies above the graphic, the click is also registered here causing the change. I will see if I find a trick to prevent this.
