wondering if anyone has experience with setting up the firmware for use with the panelmax. I've built one but overlooked the fact that it mainly has setup for Marlin (newbieee!).
I much prefer Repetier so am keen to see if I can get it working with firmware 0.91 and RAMPS 1.4
I've been using the following for wiring:
tommyc-reprap.blogspot.co.nz]
Basically, the LCD connects to RAMPS board on AUX2, the SC card on AUX3 and the rotary encoder on the SERVOS port. He does a nasty hack, soldering onto the ramps board to get a reset connection, but it seems that another pin on Aux2 or Aux3 could be used for a kill switch.
I've looked at the firmware configurator for 0.91 but haven't found an option that is similar to the way that panelmax connects, and looked through some of the source but struggle a bit with it, so some hints/tips would be helpful.
cheers
...stu
