How to invert Z dir button on host
Posted by 3ntrlab
May 05, 2013 12:40PM
Hello all,
I am working on a moving Z plane printer, much like Makerbot or Ultimaker setup.
I have no problem with Repetier Host + FW, everything is working OK, I just would like to reverse the action of + and - Z buttons to match the real thing, so when I hit the "up" button, the bed will go up.
Z bed is at zero when all up (against extruder), and at 200 when all down.
Is anything I can do to swap the Z button functions ?
Best Regards
Davide Ardizzoia
no toys here...sorry
Re: How to invert Z dir button on host
May 09, 2013 08:41AM
Really nothing to do ?
Or I am sooooooo desperately dumb not to see an obvious solution ?
Davide Ardizzoia
May 09, 2013 08:58AM
Configuration.h in your firmware.
There's a line in there to invert the direction of each Axis.
Edited 1 time(s). Last edit at 05/09/2013 08:58AM by ShadowRam.
May 09, 2013 10:50AM
Simple answer, No it is not possible.
Long answer: Get the sources and change the button codes to invert the sign and compile your version. Sorry, no easy solution at the moment.
May 09, 2013 01:13PM
> each Axis.
Won't do it.
My homing switch is at Zmax position.
Now when Z=0 bed touches extruder.
If I invert, Z=0 will be at Zmax.....
Host sources: could be a solution , but will take me a lot of time to dig into source and compile my own solution. Will put this into "thing to do into a rainy day" drawer.
Thank you,
Davide
May 09, 2013 01:44PM
If I get sometime in the future the time, I will make it an option. Also I do not like to have too many options as they tend to confuse users, but this request is not new. Seems to disturb users, where the bed moves in z direction instead of the extruder. Also it should be easy to think move extruder relative to bed.
May 09, 2013 05:10PM
Yes traditionally all jogs are of the nozzle relative to the bed. The Y axis of most Mendel type machines moves the opposite way to the button. I think it would just get more confusing if host started doing the other way.
May 10, 2013 03:24AM
Obviously each axis is being moved from associated arrow icons.
Therefore the mental picture of moving Z is Extruder assembly on sliding-bed architectures, or the bed itself when it is a lifting-bed architecture.
Surely getting too much options can be confusing (skeinforge docet), but right now Repetier host is quite spartan about options, therefore I don't see any risk to increase complexity.
The main responsibility for this issue is due to the fact that most printers home the Z when extruder is against bed, while I have chosen to home at the opposite end (zmax).
Best Regards
Davide Ardizzoia
