z axis homing in the wrong direction July 13, 2013 06:23PM |
Re: z axis homing in the wrong direction July 14, 2013 06:06AM |
#define Z_HOME_DIR 1
Re: z axis homing in the wrong direction July 14, 2013 02:36PM |
Re: z axis homing in the wrong direction July 14, 2013 03:10PM |
Re: z axis homing in the wrong direction July 14, 2013 03:17PM |
/* By default all endstops are pulled up to high. You need a pullup if you use a mechanical endstop connected with gnd. Set value to false for no pullup on this endstop. */ #define ENDSTOP_PULLUP_X_MIN true #define ENDSTOP_PULLUP_Y_MIN true #define ENDSTOP_PULLUP_Z_MIN true #define ENDSTOP_PULLUP_X_MAX true #define ENDSTOP_PULLUP_Y_MAX true #define ENDSTOP_PULLUP_Z_MAX true ... //set to true to invert the logic of the endstops #define ENDSTOP_X_MIN_INVERTING false #define ENDSTOP_Y_MIN_INVERTING false #define ENDSTOP_Z_MIN_INVERTING false #define ENDSTOP_X_MAX_INVERTING false #define ENDSTOP_Y_MAX_INVERTING false #define ENDSTOP_Z_MAX_INVERTING false
Re: z axis homing in the wrong direction July 14, 2013 03:44PM |
Re: z axis homing in the wrong direction July 14, 2013 03:46PM |
Re: z axis homing in the wrong direction July 14, 2013 03:48PM |
Re: z axis homing in the wrong direction July 14, 2013 03:58PM |
// When you have several endstops in one circuit you need to disable it after homing by moving a // small amount back. This is also the case with H-belt systems. #define ENDSTOP_X_BACK_ON_HOME 0 //DT_PERFORMANCE #define ENDSTOP_Y_BACK_ON_HOME 0 //DT_PERFORMANCE #define ENDSTOP_Z_BACK_ON_HOME 0 //DT_PERFORMANCE
Re: z axis homing in the wrong direction July 14, 2013 04:27PM |
Re: z axis homing in the wrong direction July 14, 2013 04:42PM |
Re: z axis homing in the wrong direction July 14, 2013 05:13PM |
Re: z axis homing in the wrong direction November 01, 2018 03:13AM |
Re: z axis homing in the wrong direction November 01, 2018 05:23AM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: z axis homing in the wrong direction November 05, 2018 02:42AM |
Re: z axis homing in the wrong direction November 05, 2018 02:44AM |
Re: z axis homing in the wrong direction January 02, 2019 07:16AM |
Tornado99
I have found the problem! My axis and all my settings was mirrored. After changing does settings works fine.
Now i have problem whith offsets and automatic bed leveling.
I just fun building a printer.
Thanks for the response.
Happy Printing
