RepRapPro Mono Mendel with Repetier-Host?
November 11, 2013 04:47PM
Hi all..
Wondering if anyone has used any RepRapPro machine using Repetier-Host software, as when I connect it seems connected but nothing happens.
If I need to upload Repetier-Firmware on the Melzi board it says for Huxley but it does not mention the Mono Mendel.
Has anyone tried this configuration?
Re: RepRapPro Mono Mendel with Repetier-Host?
November 13, 2013 05:41PM
hallo,
first of all, witch os are you using? Mac, Windows, Linux?
I have a ReprepPro Mono Mendel with standert marlin firmware.
It works with reptier host on Windows and Mac OS X Maveriks without any problems.
Make sure you set the baud rate in the repetier printer settings to 115200
November 16, 2013 09:27AM
Hi xack,
Thanks for your reply..
I am using Win7 64 bits.
The marlin firmware is the one shipped with the RepRapPro Mono Mendel? I mean the RepRapPro Marlin firmware?
Or you mean the standard Marlin is another I should upload to the Melzi conroler.?
Thanks for sharing this experience Xack.
November 18, 2013 06:54PM
I just set correct "Port" and "Baud rate = 115200" (Config -> Printer settings).It is working on my printer with original RepRapPro Mono Mendel firmware.
November 21, 2013 01:35PM
Hi Rafaellsi,
Thank you but,
I have tried those settings.. as I know the baud rate has to be 115200 plus the correct port. sad smiley not sure what could be happening.. as also my brother has another RepRapPro Mendel and we still can not use Repetier-Host
November 22, 2013 02:52AM
Make sure protocol is not binary, mendel does not support this. What do you see in the log window at the bottom when you connect?
November 22, 2013 02:12PM
It connects but does not do anything.
Log window does not capture anything also.
But the botton status bar says
Connected:default Extruder:0.00C command waiting, if I send e.g M555 or M503 the command waiting increase.
Thank you
