Repetier Host bug
November 15, 2013 03:48PM
Does anyone know why Repetier Host does this after about an hour of printing? It starts off fine and shows the current head travel but then suddenly looks like this and the progress doesn't update.
Thanks
Greg
open | download - repetier.jpg (579.7 KB)
Re: Repetier Host bug
November 15, 2013 04:08PM
It's not a bug - it's a feature. Under Repetier General Settings you can disable quality reduction. It's meant to reduce resource usage so that there are no delays in sending gcode to the printer.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
November 15, 2013 04:45PM
Thanks i was wondering what the quality reduction did
November 16, 2013 02:49AM
You should not disable quality reduction. If you see in the status bar FPS is already down to 12 frames per second. Commands get only send between frame updates and the print gets jerky if framerate gets too low. From the values I assume your computer has not the fastest graphic card. For bigger prints you should even think about disabling visualization completely.
November 24, 2013 07:11AM
We noticed that if you leave the tab showing the current 3D path (the animated printing), Repetier consumes more and more resources and slows down the printing. Use that view briefly, but leave another tab selected, like Temperature, so that the print does not slow down.
