Problem with homing, endstops and repetierhost December 07, 2013 01:52PM |
Re: Problem with homing, endstops and repetierhost December 07, 2013 03:02PM |
Re: Problem with homing, endstops and repetierhost December 08, 2013 11:09AM |
repetier
first, correct host settings. In printer configuration you can set x and y home position to zero, z to max. Then only do home all on a delta, it's the only homing type making sense on deltas.
Firmware. Download the developemnt version on github. it is currently preconfigured for delta, so you have a good jump start. To your settings: Gen 7 has only min endstops, so put the pins in the max endstop names and set min pins to minus one. Activate only max hardware endstops. to check pullup/ inverting use M119 to test the signals. You need L when not triggered and H when triggered.
Re: Problem with homing, endstops and repetierhost December 08, 2013 02:04PM |
Re: Problem with homing, endstops and repetierhost December 08, 2013 02:29PM |
repetier
No, 0.83 is not the development version which is 0.90. You need to select the development branch in github to see it. Here the direct link:
https://github.com/repetier/Repetier-Firmware/tree/development
Homing on delta works different. Don't think columns = axis - that is not true. Homeing x or y centers them, but that only works after successfull homing.
Have you tested if M119 goes to H when triggered for x and y?
