Integrate Kisslicer
Posted by Jomo
Integrate Kisslicer
May 27, 2014 11:47AM
Hi I am trying to integrate kisslicer using the Slicer Manager function. I added a new Kiss slicer and the path to it.
when I load a file in Repetier then Slice with the new Kiss slicer option, it open Kisslicer but then KS reports cant open file "--load" then cant open "ini". If you look at the messages in Repetier it says
"Slic3r Command C:Kisslicer.exe --load ...Slic3r.ini ...print-center C: box.STL
So it looks like it is trying to send Slic3r command line format for Kisslicer. Am I missing a step or is that a problem in Repetierhost?
Thanks
Re: Integrate Kisslicer
May 28, 2014 02:42AM
You can not use the Slic3r plugin to connect to kisslicer. These are completely different slicers.
The last time I checked kisslicer, it was also not possible to use it over command line at all. Has that changed with the new versions?
Currently the only way to use kisslicer is stand alone. You can use the watchdirectory for easy import of saved slices if you store them always in the same directory.
