So i'm using repetier software in my delta but i have problems with X_MAX_LENGTH, Y_MAX_LENGTH and Z_MAX_LENGTH. Max length shoud be the distance between the hotend
and the platform when the printer is at its home position in mm. My distance is 404mm but when i turn microstepping on (16 steps) every print is like 6 times bigger and i only can set max length to 56 becouse higher values would destroy my hotend (hotend hitting bottom). Is this normal? What to do to have normal prints?
