Feeder issues June 01, 2015 01:40PM |
Re: Feeder issues June 01, 2015 02:16PM |
Re: Feeder issues June 01, 2015 02:46PM |
Re: Feeder issues June 01, 2015 03:21PM |
Re: Feeder issues June 01, 2015 07:21PM |
romaytech
Hello,
Ok I ran an extruder test here is the results:
- Clicked slow extrude 100 in Repetier
- Measured the total distance on extruded materiel 39cm = 390mm
This does sound way too high, correct me if I am wrong it should be closed to 100mm
where would I look for the steps per mm in the firmware. I tried changing this in Configuration.h :
#define EXT0_STEPS_PER_MM 370
I have tried lower numbers but it does not seem to change anything.
Thank you for all your help
Re: Feeder issues June 02, 2015 03:20AM |
Re: Feeder issues June 04, 2015 12:54PM |
