com ports
Posted by rossco
com ports
September 27, 2015 04:09AM
hello helpers,
I have just put together my reprap pursa i3.
BUT....
Using the Repetier Host program I am not getting a connection as it is not recognizing "com port 3" so it says!
I am using a HP laptop.
Please can some body offer me some help on this matter, because I am completely stumped!
I know I have a lot to learn about the 3d printer but I am determined to beat it.
Thank you all
Rossco
Re: com ports
September 27, 2015 11:26AM
Do you see COM3 in printer settings if you open port selector? That means the port is there and working (assuming it belongs to your printer).
Leave protocol on autodetect and then try different baud rates until it succeeds.
If you could select com and get a error message you have most probably a different software using the same port. Could be repetier-server if you configured it to use the printer. In that case do not select a serial port as connector type but repetier-server in repetier-host. Then you print through the server which acts as printer spooler for you allowing to close the host without stopping the print or controlling it with you smartphone using the server url.
