prusa I3 X 3d printer
September 30, 2015 08:34AM
I have a prusa I3 x 3d printer running repetier - host geeetech v0.90d and i can't get the extruder heater above 36 degrees c. even when i go to manual controls and turn the setting up it will not rise.
Re: prusa I3 X 3d printer
September 30, 2015 08:46AM
Measure the resistence of your heating element. It should be 6-8 ohms for 12vdc, 3-4 ohms for 24vdc.
What voltage are you driving it at? I assume 12vdc.
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
September 30, 2015 10:53AM
i would assume 12v but i dont know my boss threw this printer at me and told me to build this thing and get it working so thats what im doing lol.
September 30, 2015 11:11AM
Hmmm... confused smiley
It is difficult to recommend anything without more information.
What hot end are you using?
For example, the E3D has become a very popular hot end and it comes with heater cartridges for 12vdc and 24vdc.
If you are running 12vdc but have a 24vdc heater cartridge then this would never get hot enough (although it should get up to ~50°C).
Bob Morrison
September 30, 2015 11:19AM
mk8 extruder the stock one that came with the geeetech prusa I3 x
September 30, 2015 11:50AM
So your hotend comes completely assembled and is supposed to have a 30 watt, 12vdc heating element.
Is the heating element on constantly?
Does the firmware (FW) perhaps have a MAXTEMP defined?
Bob Morrison
September 30, 2015 02:30PM
hotend came assembled already, yes. heating element isnt hot so i would guess no. and max temp i came in @200 i have it @ 210 and its says 24deg.
September 30, 2015 04:27PM
on the printer lcd its says its ready to print but the extruder wont heat up. now its reading min temp
October 01, 2015 04:51AM
You need to get down to basics.
There is a pin that that is attached to the heating cartridge.
When output is 12vdc it heats, when output is 0vdc it does not heat.
Also the heating cartridge must have a finite resistance.
MEASURE THE RESISTENCE. If ~0 Ω or ~ infinite (millions) Ω then your heating cartridge is defective.
If it has a low Ω value say 2 - 8 Ω it is probably OK, then you need to see if 12vdc is being output by the pin connected to the heating cartridge (or not).
Edited 1 time(s). Last edit at 10/01/2015 04:52AM by rhmorrison.
Bob Morrison
October 01, 2015 11:09AM
im getting .540- .550 ac from computer board and i got 3.** ohms across the heating block. I dont see a pin unless your talking about the alan key screw that is attached to the heating block?
October 01, 2015 11:20AM
3 Ω @ 12 vdc = 48 watts power (should be enough).
You don't measure the heating block you measure the DC voltage going to the heating cartridge.
One side is connected to ground the other to the output of the FET that is driven by the E0 output of the board.
Bob Morrison
October 01, 2015 11:27AM
What electronics board is your printer using?
Bob Morrison
October 01, 2015 01:04PM
gt2560+4 a4988
October 01, 2015 01:37PM
computer board
open | download - 20151001_130952.jpg (376.3 KB)
October 02, 2015 03:51AM
According to the wiring diagram on the GT2560 Geeetech Wiki page you have the hotend plugged into Extruder 2 (or the hotbed connector instead of Extruder 1).
Make sure that the hotbed is plugged into the middle connector and the hotend cable into the bottom connector (in your picture where no wires are connected).
Bob Morrison
October 02, 2015 10:03AM
ok changed the wiring connector. how do i clear the min temp error on lcd screen? i got both on but neither are working
October 02, 2015 10:17AM
I think you need to start at the beginning and verify all connections and go through their setup and initialization/calibration procedures.
GeeeTech also has a forum which would be a better place to ask questions caused by problems with their hardware.
Search for "ERR: MINTEMP" on the forum.
Edited 1 time(s). Last edit at 10/02/2015 10:37AM by rhmorrison.
Bob Morrison
