So Ive enabled auto bed leveling and have set my offset for Z probe within the slicer settings. Im using marlin Firmware with ramps 1.4. If you see the attached screen shots, you can see a normal model before slicing, but after slicing it drops the print below the print bed. This does not cause a print head crash, rather it skips those layers, In this particular model 49 of them, And it reflects like wise in the print. If i watch the status bar at the bottom of the screen, the info reflects incorrectly as well. It seems to print one solid layer and then Straight to infill but the solid layer is so thin its more like a raft(.1mm layer height)
I dunno what to do about it. Ive tried readjusting the Marlin offset, checked through Repetier for something, and googling this problem but i have found nothing. Thanks everyone.
