Problema al imprimir desde la tarjeta SD. August 01, 2013 07:26AM |
Re: Problema al imprimir desde la tarjeta SD. August 01, 2013 08:16AM |
Re: Problema al imprimir desde la tarjeta SD. August 01, 2013 09:26AM |
Re: Problema al imprimir desde la tarjeta SD. August 01, 2013 09:47AM |
Moderator Registered: 12 years ago Posts: 367 |
Re: Problema al imprimir desde la tarjeta SD. August 01, 2013 03:51PM |
; generated by Slic3r 0.9.10b on 2013-07-16 at 00:24:45 ; layer_height = 0.35 ; perimeters = 3 ; top_solid_layers = 3 ; bottom_solid_layers = 3 ; fill_density = 0.4 ; perimeter_speed = 30 ; infill_speed = 60 ; travel_speed = 130 ; nozzle_diameter = 0.35 ; filament_diameter = 2.85 ; extrusion_multiplier = 1 ; perimeters extrusion width = 0.37mm ; infill extrusion width = 0.37mm ; solid infill extrusion width = 0.37mm ; top infill extrusion width = 0.37mm ; first layer extrusion width = 0.20mm G21 ; set units to millimeters M190 S80 ; wait for bed temperature to be reached M104 S215 ; set temperature G28 ; home all axes M109 S215 ; wait for temperature to be reached G90 ; use absolute coordinates G92 E0 M82 ; use absolute distances for extrusion G1 F1800.000 E-1.00000 G92 E0
G92 E0 M104 S0 ; turn off temperature M190 S0 ; turn off temperature G28 X0 ; home X axis M84 ; disable motors ; filament used = 464.1mm (3.0cm3)
M110 G21 M190 S70 M104 S210 G28 M109 S210 G90 G92 E0 M82 G1 Z0.050 F7800.000
G1 Z26.150 F7800.000 G92 E0 M104 S0 M190 S0 G28 X0 M84 M110
Re: Problema al imprimir desde la tarjeta SD. August 01, 2013 05:49PM |
Re: Problema al imprimir desde la tarjeta SD. August 01, 2013 08:51PM |
Re: Problema al imprimir desde la tarjeta SD. August 02, 2013 06:48AM |
