Tip del dia March 11, 2014 02:50AM |
Re: Tip del dia March 11, 2014 03:29AM |
Re: Tip del dia March 11, 2014 12:15PM |
Re: Tip del dia March 12, 2014 07:24PM |
Re: Tip del dia March 12, 2014 07:27PM |
Re: Tip del dia March 13, 2014 08:36AM |
Re: Tip del dia March 13, 2014 08:59AM |
Re: Tip del dia March 13, 2014 09:02AM |
Re: Tip del dia March 14, 2014 01:30PM |
Re: Tip del dia March 14, 2014 01:43PM |
Re: Tip del dia March 27, 2014 09:32AM |
Re: Tip del dia March 27, 2014 07:05PM |
Re: Tip del dia March 28, 2014 03:26PM |
Re: Tip del dia April 04, 2014 09:36AM |
To avoid Z ribbing, you should always choose a layer height that is a multiple of your full-step length. To calculate the full-step length for the screws you're using, take the pitch of your screws (I recommend M6, with a pitch of 1mm) and divide by the number of full-steps per rotation on your motors (usually 200). Microsteps are not reliably accurate enough, so ignore them for this calculation (though using microstepping will still make them smoother and quieter).
Re: Tip del dia April 04, 2014 11:55AM |
luismanson
Dejo algo que acabo de leer/aprender y puede servir:
Taxonomy of Z axis artifacts in extrusion-based 3d printing
Basicamente, recomienda usar un alto de capa que es multiplo del largo (elevacion) con un paso completo (segun entiendo)
Para calcular el valor del largo de paso completo hay que tener el paso de la varilla y dividirlo por el numero de pasos del motor por vuelta. No hay que confiard en micro stepping para este calculo porque no son lo suficiente preciso
Re: Tip del dia April 04, 2014 12:36PM |
nic0laz
la mayoria usamos varillas metricas para z, asiq ue no hace falta sacar cuentas, con usar numeros "pares" alcanza, por ejemplo, 0.15 no seria "par", pero si 0.16 o 0.152.
se entiende?
luismanson
Ojo que depende de que tipo de varilla roscada tenes en Z, porque por ejemplo 0.22 en M5 da un numero justo de pasos pero en M8 no, y 0.22 es par.Si bien es una heuristica bastante oportuna para los pitch o paso que son múltiplos de 2, en particular para M5 sirve, no aplica a las métricas con pitch o paso impar como M8 que es 1,25mm
Saludos,
Javier
jfa3D.com.ar
Re: Tip del dia April 04, 2014 01:23PM |
jameghino
nic0laz
se entiende?
luismanson
Saludos,
Javier
jfa3D.com.ar
Re: Tip del dia August 18, 2014 06:59AM |
Re: Tip del dia August 18, 2014 08:52PM |
Pointless
El infill honeycomb del slic3r con ancho de extrusion obseno sale muy bien (ahora estoy probando ancho de extrusion de 1mm con boquilla de 0.4). Hace MUCHOS menos hexagonos que usando por ejemplo 0.5 por lo que la velocidad es infinitamente mayor, la maquina sufre mucho menos (menos cambios de direccion). Me queda por ver la durabilidad de las piezas que salen.
Re: Tip del dia August 18, 2014 09:28PM |
Re: Tip del dia August 18, 2014 10:32PM |
Re: Tip del dia August 19, 2014 12:04AM |
Re: Tip del dia August 20, 2014 06:45PM |
Lechonquinto
cuando necesito que un soporte no deje marcas, paro la impresión en la capa en que termina de hacer el soporte y con aceite liviano como el de maquina de coser y un pincel, aplico una fina capa de aceite en el soporte y continuar la impresión
( evitar esquinas, no aplica a piezas complejas ) a veces el soporte se despega solo al enfriarse
Re: Tip del dia August 20, 2014 07:16PM |
Re: Tip del dia August 20, 2014 08:06PM |
Re: Tip del dia August 21, 2014 04:49PM |
Moskito
Algo que me resulto muy util a la hora de hacer que slic3r no decida absolutamente todo. ANCHOS DE EXTRUSIÓN
[attachment 38581 sli.jpg]
Re: Tip del dia August 21, 2014 06:28PM |
Drakorosario
Moskito
Mosquito te hago una consulta.....
Leyendo un Manual de slic3r vi que decia en referencia a esto que estaba en etapa de prueba (el manual es viejo) pero recomendaba llevar el primer layer a 100% en lugar de 200%. Lo probaste? Cambia en algo?
Re: Tip del dia August 22, 2014 07:21PM |
Re: Tip del dia August 28, 2014 02:55AM |
Re: Tip del dia August 28, 2014 05:17PM |
Moderator Registered: 12 years ago Posts: 367 |
Pointless
Mientras armamos nuestras impresoras, routers, robots o maquinas para conquistar al mundo de turno es aconsejable en caso de utilizar rodamientos lineales hacer las siguientes dos cosas:
- Matarle toda la rebarba a las puntas de las varillas lisas y en lo posible bicelarle las puntas
- Lubricar los rodamientos ANTES de ponerlos en los ejes
De esta forma se van a ahorrar quilombos por perdidas de bolitas del rodamiento y rayones en las varillas lisas
