Re: first connecting to mac August 01, 2014 05:08AM |
Re: first connecting to mac August 01, 2014 07:40AM |
Re: first connecting to mac August 01, 2014 08:40AM |
Re: first connecting to mac August 01, 2014 09:11AM |
Re: first connecting to mac August 01, 2014 12:16PM |
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: first connecting to mac August 02, 2014 09:16AM |
Re: first connecting to mac August 02, 2014 05:22PM |
mdcompositi
I'm using pronterface and kisslicer but I could not!
I set all the different settings but when I start a print of a gcode generated by kisslicer, the printer seems crazy!
especially the extruder runs faster without stopping!
I did three prints of which I enclose photos by using Cura and start the printer with repetier-host
The main problem is z-axis, for example the cube 20x20x10 has been realized only half empty and the cube 2x2x1 the same!
also measures of the latter along the x and y are not real, in fact, measure 3x0.5 cm!
calibration angle 50mm is 75mm!!
the third printed file (the one that came better), is a cm bigger( calibration angle 50mm is 75mm!!)
I have a z-axis threaded rod 6cm connected with coupler
Re: first connecting to mac August 03, 2014 03:15AM |
Re: first connecting to mac August 06, 2014 05:12AM |
Re: first connecting to mac August 06, 2014 11:30AM |
mdcompositi
I solved this problem!
I recalculated the steps per mm using this [calculator.josefprusa.cz]
Now the printer is fine, just settle the whole thing and when I'll make some decent print I'll public some photos!
with respect to the z axis, I used to twice the silicone tube and the holder printable but it happened that was cut and had to do it again.
can you better explain problems regarding use of the coupler?
why it creates problems?
For the moment I'm using Cura but as soon as possible I would like to resolve the problems with kisslicer
