Huxley sized Mendel-90?
Posted by oz9ny
January 19, 2013 07:53AM
Can you tell a little about issues when scaling down the Mendel-90 to a Huxley sized printer. I have tried changing parameters and studyed the output from make_machine.py.
The Mendel-90 will take up too much space in my small workshop :-)
/Niels
Re: Huxley sized Mendel-90?
January 19, 2013 10:23AM
It is something I am working on. Currently it scales down OK with 6mm rods and NEMA14 motors but it still uses the Wade's extruder, which is too big. I plan to use something like Ron's compact extruder to make it light enough for the smaller motors and shorten the X carriage to get the overall width down. I will also use 1.75mm filament so the spool is small enough to fit between the stays.
January 19, 2013 11:26AM
Thanks. I had a bowden system in (with all pro and cons) mind for my version.
/niels
January 19, 2013 01:29PM
I have never tried Bowden but there isn't much point making the extruder lighter than the moving bed. I think Bowden only makes sense for moving head machines, or if you want lots of nozzles.
