Cura settings for Mendel90 May 27, 2013 01:51PM |
Re: Cura settings for Mendel90 June 01, 2013 08:54PM |
Machine width (mm) -> 200 Machine depth (mm) -> 200 Machine height (mm) -> 200 Nozzle Size (mm) -> 0.4 Heated Bed -> yes Bed Center is 0,0,0 (RoStock) -> yes
Absolute_Extrusion_Distance': "True", Relative_Extrusion_Distance': "False",
Absolute_Extrusion_Distance': "False", Relative_Extrusion_Distance': "True",
G21 ;metric values G90 ;absolute positioning M107 ;start with the fan off M83 G28 G1 X5 Y98 F9000 G1 Z0.05 M109 S{print_temperature} G92 E0 G1 E2 F50 G1 E-1.5 F1200 G1 X40 F4000 G1 Z0.3 G1 X-43.305 Y-10.104 Z0.3 F12000.0 G1 F1200.0 G1 E1.5 G1 F{travel_speed} M117 Printing...
M104 S0 M140 S0 G1 X-100 Y100 F9000 G1 Z200 M84
Re: Cura settings for Mendel90 June 05, 2013 03:54PM |
Re: Cura settings for Mendel90 June 05, 2013 06:18PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Cura settings for Mendel90 June 06, 2013 02:04AM |
Re: Cura settings for Mendel90 June 06, 2013 04:04AM |
Re: Cura settings for Mendel90 June 15, 2013 02:51AM |
Re: Cura settings for Mendel90 July 09, 2013 06:45PM |
Re: Cura settings for Mendel90 August 03, 2013 01:51AM |
You must locate the settings file , which in my case (Mac Os X version) is:
Cura.app/Contents/Resources/Cura/slice/cura_sf/fabmetheus_utilities/settings.py
Re: Cura settings for Mendel90 August 03, 2013 02:18AM |
Re: Cura settings for Mendel90 August 03, 2013 05:26AM |
Re: Cura settings for Mendel90 August 03, 2013 05:44AM |
Re: Cura settings for Mendel90 August 03, 2013 09:04AM |
Re: Cura settings for Mendel90 August 03, 2013 10:06AM |
Re: Cura settings for Mendel90 August 04, 2013 05:39PM |
Re: Cura settings for Mendel90 November 29, 2014 08:35AM |
Re: Cura settings for Mendel90 November 29, 2014 10:50AM |
;Sliced at: {day} {date} {time} ;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density} ;Print time: {print_time} ;Filament used: {filament_amount}m {filament_weight}g ;Filament cost: {filament_cost} G21 ; metric values G90 ; absolute positioning M83 ; set extruder to relative mode G92 E0 ; zero the extruded length M107 ; start with the fan off G28 ; home all axes G1 X0 Y98 F6000 ; go to the middle of the front G1 Z0.05 ; close to the bed M104 S{print_temperature} ; set extruder temp M190 S{print_bed_temperature} ; set bed temp & wait M109 S{print_temperature} ; wait for extruder temp G1 X50 E5 F200 ; make a thick line to prime extruder G1 E-1 F1200 ; retract a little G1 Z0.3 ; lift Z M82 ; set extruder to absolute mode G92 E0 ; zero the extruded length againend.gcode:
;End GCode M104 S0 ; turn off extruder M140 S0 ; bed off M107 ; carriage fan off M83 ; set extruder to relative mode G92 E0 ; zero the extruded length G1 E-1 F1200 ; extra retract ;G1 X-100 Y100 F6000 ; go to back ;M42 P28 S255 ; bed fan on G1 Z200 X-100 F6000 ; go to top ;G4 P300000 ;M42 P28 S0 ; bed fan off G1 Y-100 ; bed to front M84 ; disable motors ;{profile_string}
Re: Cura settings for Mendel90 November 30, 2014 07:18AM |
Re: Cura settings for Mendel90 November 30, 2014 07:37AM |
Re: Cura settings for Mendel90 November 30, 2014 09:39AM |
Re: Cura settings for Mendel90 November 30, 2014 02:24PM |
Re: Cura settings for Mendel90 November 30, 2014 02:54PM |
Re: Cura settings for Mendel90 November 30, 2014 04:47PM |
Re: Cura settings for Mendel90 December 07, 2014 06:21AM |
Re: Cura settings for Mendel90 December 07, 2014 09:18AM |
Re: Cura settings for Mendel90 December 07, 2014 09:39AM |
Re: Cura settings for Mendel90 December 07, 2014 11:28AM |
Re: Cura settings for Mendel90 December 07, 2014 02:05PM |
Re: Cura settings for Mendel90 December 07, 2014 02:39PM |
Re: Cura settings for Mendel90 December 07, 2014 02:52PM |
