COM speed - going beyond 250K ? June 28, 2013 05:43PM |
Anonymous User
Re: COM speed - going beyond 250K ? July 05, 2013 02:51PM |
Re: COM speed - going beyond 250K ? July 06, 2013 07:04AM |
What is the highest speed that would still work
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: COM speed - going beyond 250K ? July 06, 2013 08:46AM |
you know - to learn from someone elses's mistakes.|
Re: COM speed - going beyond 250K ? July 06, 2013 02:35PM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: COM speed - going beyond 250K ? July 07, 2013 07:24AM |
Printing via USB usually works, but will occasionally have errors due to the PC not responding in real time, or it might disconnect if the ground loop picks up RFI.
Re: COM speed - going beyond 250K ? July 07, 2013 08:41AM |
Re: COM speed - going beyond 250K ? July 08, 2013 04:40AM |
I can't think of any professional devices that use USB and are grounded.
Re: COM speed - going beyond 250K ? July 08, 2013 05:17AM |
Re: COM speed - going beyond 250K ? July 08, 2013 09:29AM |
I find if I plug machine and PC in the same wall socket or extension I don't get any disconnects but if I plug them in to sockets far apart I will get a disconnect every time I switch the fluorescent light in the same room.
Re: COM speed - going beyond 250K ? July 08, 2013 09:31AM |
Re: COM speed - going beyond 250K ? July 08, 2013 09:34AM |
Re: COM speed - going beyond 250K ? July 08, 2013 09:38AM |
Re: COM speed - going beyond 250K ? July 08, 2013 10:16AM |
Re: COM speed - going beyond 250K ? July 09, 2013 07:41AM |
Re: COM speed - going beyond 250K ? July 09, 2013 08:16AM |
Anonymous User
Re: COM speed - going beyond 250K ? July 09, 2013 02:59PM |
Re: COM speed - going beyond 250K ? July 09, 2013 03:03PM |
Re: COM speed - going beyond 250K ? July 12, 2013 05:08AM |
Re: COM speed - going beyond 250K ? July 13, 2013 07:04AM |
I can change Melzi to include optional optocouplers (with solder jumpers as alternative).
Re: COM speed - going beyond 250K ? July 13, 2013 10:17AM |
But, even with differential data, there are times when single-ended signalling is used in the USB: The end-of-packet is signalled with a single-ended-zero (SE0), namely, both D+ and D- in low state. This state last the time of 2 bits. if SE0 last for more than 10ms it means a bus reset.
This single-ended signalling makes the USB quite sensitive to electromagnetic interference, like those I found recently when a hair dryer motor was causing a lot of disconnects in a nearby USB peripheral. And no common-mode filters can be effectively used because these can degrade the SE0 signal...
Re: COM speed - going beyond 250K ? July 30, 2013 05:48PM |
Re: COM speed - going beyond 250K ? July 30, 2013 08:15PM |
