Re: Help! Filament jammed! April 25, 2015 01:05PM |
Re: Help! Filament jammed! April 25, 2015 05:00PM |
Re: Help! Filament jammed! April 26, 2015 12:23AM |
Re: Help! Filament jammed! April 28, 2015 10:11PM |
Re: Help! Filament jammed! September 04, 2015 09:51AM |
I assume it is PLA. If you have a heat gun then heat the top end of the extruder to about 70C. It then becomes like rubber and you can grip it with snipe nosed pliers and pull out the bit in the hex grub screw. It should then work again. It is only the fact that the hole through the grub screw is bigger than the normal filament path that is the Achilles heel of the JHead.
Re: Help! Filament jammed! September 04, 2015 10:28AM |
Re: Help! Filament jammed! September 27, 2015 04:29AM |
Re: Help! Filament jammed! September 27, 2015 07:57AM |
Admin Registered: 17 years ago Posts: 7,879 |
