[SOLVED] Printing small areas in ABS without droop? October 16, 2014 04:54AM |
Re: Printing small areas in ABS without droop? October 16, 2014 10:56AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Printing small areas in ABS without droop? October 17, 2014 05:31AM |
nophead
I think the main reason for the droop is not the lack of cooling. It is because it slows down so much that the die swell is much less, so the filament tension is less. You could try not slowing down and turning the fan on for just those layers instead. I have never tried a fan on ABS with a heated bed. I don't even fit the fan on my production machines.
Activate Cool: Checked Full Fan Speed (0 - 255): 255 Do Not Use Fan Before Layer (integer): 1 Maximum Layer Time for Fan use (seconds): 5.0 Full Fan Speed Below Layer Time (seconds): 5.0 Maximum Cool (Celcius): 0 Minumum Layer Time (seconds): 5.0I have produced a very good result but fan-only is not quite the solution, you do need to set a minimum layer time and 5 seconds appears to be acceptable.
Re: Printing small areas in ABS without droop? October 17, 2014 06:16AM |
Material: 3dfilaprint White ABS 3mm Print speed: 40mm/s, 20mm/s first layer Layer height: 0.4mm Line width: 0.6mm Infill: 90% Extruder temperature: 220C Heated Bed temperature: 125C (for 110C at glass surface) Build surface: 2mm plain glass with ABS Juice Slicer: skeinforge Special processing: Filament oversized by 0.055mm in slicer, X-carriage Fan on for Ribbon Cable post last 1cm
Re: [SOLVED] Printing small areas in ABS without droop? October 17, 2014 06:41AM |
Re: [SOLVED] Printing small areas in ABS without droop? October 17, 2014 07:08AM |
Re: Printing small areas in ABS without droop? October 17, 2014 08:22AM |
Re: [SOLVED] Printing small areas in ABS without droop? October 17, 2014 08:46AM |
neildarlow
Read the Technical details above regarding Filament Diameter oversizing (e.g. 2.96mm --> 3.015mm).
Re: [SOLVED] Printing small areas in ABS without droop? October 17, 2014 09:18AM |
Re: [SOLVED] Printing small areas in ABS without droop? October 17, 2014 11:16AM |
Re: [SOLVED] Printing small areas in ABS without droop? October 17, 2014 01:55PM |
nophead
I don't know how you can print 0.4 by 0.6 in PLA with a 0.4 nozzle. It doesn't have enough die swell. Are you sure you haven't accidentally increased the nozzle aperture?
Re: [SOLVED] Printing small areas in ABS without droop? October 17, 2014 02:23PM |
Re: [SOLVED] Printing small areas in ABS without droop? October 17, 2014 06:20PM |
Re: [SOLVED] Printing small areas in ABS without droop? October 17, 2014 08:26PM |
Re: [SOLVED] Printing small areas in ABS without droop? October 19, 2014 05:42AM |
Alzibiff
I will have a go with this over the weekend as I want to print out another part cooling fan mount. I'll get back to let you know how I got on.
Re: [SOLVED] Printing small areas in ABS without droop? October 19, 2014 10:45AM |
nophead
What size does the ABS come out at?
Re: [SOLVED] Printing small areas in ABS without droop? October 19, 2014 11:47AM |
Re: [SOLVED] Printing small areas in ABS without droop? October 19, 2014 12:46PM |
Re: [SOLVED] Printing small areas in ABS without droop? October 19, 2014 02:21PM |
Re: [SOLVED] Printing small areas in ABS without droop? October 19, 2014 02:38PM |
