The Mendel 90 uses a type of 15 pin D connector that you slip a ribbon cable into and squeeze. Sharp things connect it and everything is good. Amazingly good, you should see the mess I got myself in trying to solder up a normal one pin by pin...
I can't find both male and female versions on (in this case RS Components).
Does anyone know what they are actually called and point out where to get them? I don't know what the squeeze mechanism is called :/
Thank you.
