Mendel90 E3D v6 Conversion June 15, 2015 02:45AM |
Re: Mendel90 E3D v6 Conversion June 15, 2015 03:57AM |
Re: Mendel90 E3D v6 Conversion June 15, 2015 06:40AM |
Re: Mendel90 E3D v6 Conversion June 15, 2015 05:40PM |
danielis
Look here: [forums.reprap.org] scroll down.
Nophead has created a branch in his repository for E3D.
Re: Mendel90 E3D v6 Conversion June 16, 2015 03:43PM |
Re: Mendel90 E3D v6 Conversion June 16, 2015 05:17PM |
Re: Mendel90 E3D v6 Conversion June 16, 2015 05:46PM |
hsbontop
Using these with great results.
http://www.thingiverse.com/thing:884248
http://www.thingiverse.com/thing:491316
Re: Mendel90 E3D v6 Conversion June 17, 2015 03:24AM |
Re: Mendel90 E3D v6 Conversion June 17, 2015 05:49AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Mendel90 E3D v6 Conversion July 23, 2015 03:10AM |
Re: Mendel90 E3D v6 Conversion July 25, 2015 07:24PM |
Re: Mendel90 E3D v6 Conversion July 28, 2015 04:55AM |
Re: Mendel90 E3D v6 Conversion July 28, 2015 09:54AM |
Re: Mendel90 E3D v6 Conversion July 28, 2015 03:42PM |
Re: Mendel90 E3D v6 Conversion July 28, 2015 05:34PM |
Re: Mendel90 E3D v6 Conversion July 28, 2015 06:05PM |
nophead
Hosts normally work in mm/m. I normally test 3mm filament at 60mm/m so for 1.75mm that would be about 180mm/m or 3mm/s.
Re: Mendel90 E3D v6 Conversion July 28, 2015 06:29PM |
Re: Mendel90 E3D v6 Conversion July 28, 2015 06:34PM |
Re: Mendel90 E3D v6 Conversion July 28, 2015 06:35PM |
Re: Mendel90 E3D v6 Conversion July 28, 2015 07:41PM |
09zx-6r
it looks like the bed is not level... causing the nozzle to touch the bed and stop the flow at the end of the nozzle untill it gets to a greater gap between the bed and nozzle...i had that happen to me when i first installed the e3dv6... but i also had made changes to the bed causing a need for releveling... but none the less, if your printing at the correct speed, then id look at bed level...
Re: Mendel90 E3D v6 Conversion July 29, 2015 08:40AM |
Re: Mendel90 E3D v6 Conversion July 29, 2015 10:35PM |
