Startcode in Simplify3d won´t work
July 12, 2015 04:31AM
Hey guys,
after upgrading to S3D V3.0 my startcode isn´t working anymore. i have to click force next so that the print starts.
and when i do, its much too fast. i compared the settings for the print speed, they are the same.
so, does anyone have a working configuration or can guess a stard code?
should go to front middle, then heat up bed, heat up extruder, and then print. wiping the nozzle isnt necessary,
i print 3 skirtlines to fill and clean the nozzle
thanks in advance
Re: Startcode in Simplify3d won´t work
July 12, 2015 05:58AM
If you had working start GCode in one version of S3D, and an update has broken it, It is probably best that you ask in a forum specifically aimed at S3D.
Regards,
Neil Darlow
I try to write with consideration for all nationalities. Please let me know if something is unclear.
Printing with Mendel90 from fedora 25 using Cura, FreeCAD, MeshLab, OpenSCAD, Skeinforge and Slic3r tools.
July 12, 2015 06:04AM
hi, yeah, sounds reasonable. but i thought one of the users here might have the same problem. i´m sorry.
can i ask for a working stardcode? let´s think my startcode doesn´t work at all
July 13, 2015 03:53AM
I have no idea how S3D works but here is my start gcode (I use Slic3r):
; ***** Ooze-free unattended start with wipe, front edge (LEDs ON) *****
G90					; Set positioning to absolute
G21					; Set units to millimeters (if required?)
G28					; Home all axes
G92 E0					; Reset extruder
M42 S255 P28				; Turn on the gantry LEDs on FET 1
G1 Z200 X-45 Y95 F12000			; Move above block point
M190 S[first_layer_bed_temperature]	; Pre-heat the bed & wait as it takes longer
M117 Remove insulation!
M104 S[first_layer_temperature]		; Start heating the extruder before lowering the nozzle
G1 Z0.1 X-45 Y95 F12000			; Lower to block point and block nozzle
M109 S[first_layer_temperature]		; Wait for extruder to reach first layer temperature
G4 S120					; Wait another 120 seconds for nozzle length to stabilise
G1 E3					; Extrude 3 mm of filament
G1 X45 Y95 F12000			; Wipe nozzle across the bed
G1 Z1 					; Raise nozzle to 1 mm ready to begin main sequence
M201 X2000 Y2000 			; max acceleration in X and Y
M117 Printing...
Printing three skirts takes longer and uses up more bed space so I've no idea why you'd want to do that over a quick wipe at the beginning but I'm sure you can work out which bits you need to remove if you don't want the wipe.
