Power Issues? April 29, 2022 06:07PM |
Re: Power Issues? April 29, 2022 09:17PM |
Re: Power Issues? May 01, 2022 01:40AM |
Re: Power Issues? May 01, 2022 08:36AM |
Re: Power Issues? May 02, 2022 04:46PM |
Re: Power Issues? May 02, 2022 05:17PM |
JaredTS486
I will have to see if I can find another power supply to rule out the one I have being faulty. It is a 500w EVGA power supply.
I also re-soldered / cleaned the the connections that mount into the screw terminals and added an extra 12v wire from the power supply rails to the 12v input on the board.
This seemed to slightly reduce the min / max temp spikes. Please let me know if anyone has any more suggestions.
Thanks again,
Re: Power Issues? May 03, 2022 01:26PM |
Re: Power Issues? May 03, 2022 01:53PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Power Issues? May 03, 2022 04:11PM |
nophead
I don't think it is a power issue. A small change in voltage would be easily corrected by the control. Perhaps the PID tuning is off as it looks almost like a sinusoidal oscillation.
Re: Power Issues? May 03, 2022 04:37PM |
Re: Power Issues? May 03, 2022 05:11PM |
nophead
Have you got PID enabled for the BED? It is better than bang-bang because the fluctuations from bang-bang bang can cause the bed to flex.
I don't see how minor voltage fluctuations can cause big changes in hot end temperature.
Are you using the original Melzi we supplied or a different one? Perhaps voltage drops in the ground traces of the PCB are causing thermistor reading variations.
Re: Power Issues? May 04, 2022 05:18AM |
Re: Power Issues? May 04, 2022 04:07PM |
Re: Power Issues? May 05, 2022 06:49AM |
Re: Power Issues? May 05, 2022 07:05AM |
Re: Power Issues? May 06, 2022 02:33PM |
nophead
When using an E3D hot end I did need to increase the PID functional range to 20 when using it to print polycarbonate at 275C. I also changed THERMAL_PROTECTION_HYSTERESIS to 10.
Marlin temperature control is a nightmare of complexity. On my old machines with my own firmware I simply used bang-bang and it works just as well, no tuning. It doesn't work on Marlin because it doesn't sample fast enough. I sample probably somewhere around 1Khz, when the temperature is close to the set point noise in the readings causes PWM like control.
Re: Power Issues? May 06, 2022 06:21PM |
nophead
Re: Power Issues? May 07, 2022 03:18AM |
