Re: Malé CNC + 3d tisk August 05, 2015 03:17PM |
Re: Malé CNC + 3d tisk August 07, 2015 03:36AM |
Re: Malé CNC + 3d tisk August 08, 2015 04:53PM |
Re: Malé CNC + 3d tisk August 17, 2015 03:03AM |
Re: Malé CNC + 3d tisk August 18, 2015 03:06AM |
Re: Malé CNC + 3d tisk August 18, 2015 11:00AM |
Re: Malé CNC + 3d tisk August 18, 2015 01:41PM |
Re: Malé CNC + 3d tisk August 18, 2015 01:44PM |
Re: Malé CNC + 3d tisk August 18, 2015 01:45PM |
dan
Ja jsem prispel tomuhle typkovi [sites.google.com] nevypada to zle a co jsem tak cetl, tak je to i pouzitelne. Hraju si s tim zatim bez ztroje. Verze 1.0 je i free a mela by taky chodit. Jinak ja cekam na kulickovy srouby, pojal jsem tu frezku trochu fortelneji
Re: Malé CNC + 3d tisk August 18, 2015 01:53PM |
Takze v soucasne dobe to bude mensi klasika. Predstavu mam jasnou, ale cekam na ty srouby kvuli rozmerum a zatim tvorim vreteno. Zbytek namaluju behem chvile, az budu mit zakladni material. Pak budou nejake ty obrazky.
Re: Malé CNC + 3d tisk August 18, 2015 01:57PM |
Re: Malé CNC + 3d tisk August 18, 2015 02:00PM |
A cenove to take jde.
Re: Malé CNC + 3d tisk August 18, 2015 02:04PM |
Re: Malé CNC + 3d tisk August 18, 2015 02:14PM |
Re: Malé CNC + 3d tisk August 18, 2015 02:18PM |
Re: Malé CNC + 3d tisk August 19, 2015 03:30AM |
Re: Malé CNC + 3d tisk August 19, 2015 03:36AM |
Re: Malé CNC + 3d tisk August 19, 2015 04:00AM |
Re: Malé CNC + 3d tisk August 19, 2015 05:25AM |
Re: Malé CNC + 3d tisk August 19, 2015 07:48AM |
Re: Malé CNC + 3d tisk August 20, 2015 04:15AM |
Moderator Registered: 12 years ago Posts: 1,038 |
Bojkas
Mám objednané mechanické endstopy, ale se třemi žílami, mám jeden drát odstřihnout, nebo to tam můžu napojit jako optický do všech tří? [www.aliexpress.com]
Re: Malé CNC + 3d tisk August 20, 2015 04:21AM |
Re: Malé CNC + 3d tisk August 20, 2015 04:34AM |
Re: Malé CNC + 3d tisk August 20, 2015 04:38AM |
Re: Malé CNC + 3d tisk August 20, 2015 04:44AM |
Re: Malé CNC + 3d tisk August 20, 2015 05:23AM |
dan
A proc si zkousel pripojit vsecky 3? jaky to ma vyznam? Vzdyt je to prepinaci kontakt u ktereho stejne arduino vyuziva bud jeden nebo druhej.
Jedine k cemu to je dobre, tak je prave vypaleni stabliku, nebo vstupu na arduino pri spatne konfiguraci.
a priznavam, ze to je trosku zbytecne, ale mam aspon jistotu, ze mi po odzemneni (rozepnuti kontaktu) neni vstup na vzduchu (i kdyz to resi arduino interne a staci jen prizemnit vstup)
Re: Malé CNC + 3d tisk August 20, 2015 05:29AM |
Bojkas
Tak pro výměnu CNC a 3D tisku budu flashovat firmware Repetier a GRLB for Ramps 1.4. Je to otázka půl minuty a funguje to. Potřebuji ale poradit, kde můžu přehodit ovládání motorů. Mám to zapojené podle repetieru, ale při přehrání na GRLB je prohozené Y se Z. :-/
Re: Malé CNC + 3d tisk August 20, 2015 05:41AM |
Re: Malé CNC + 3d tisk August 20, 2015 05:55AM |
Bojkas
To jsem včera zkoušel, prohodil sem to i s hodnotami, ale byl tam asi nějaký error a při pokusu o pohyb mi to tam napsalo nějaké šílené hodnoty posuvu a motor se začal točit, dokud jsem nedal nouzové přerušení.
EDIT:
ještě k endstopům. Pokud jich budu chtít použít 6, fungují ty ostatní konektory MAX na ramps 1.4? [forums.reprap.org]
Re: Malé CNC + 3d tisk August 20, 2015 07:46AM |
