Re: Höhe des Druckbett justieren 08. November 2015 12:24 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 2.094 |
Re: Höhe des Druckbett justieren 08. November 2015 13:20 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 1.446 |
Re: Höhe des Druckbett justieren 08. November 2015 13:43 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 56 |
Re: Höhe des Druckbett justieren 08. November 2015 13:51 |
Re: Höhe des Druckbett justieren 08. November 2015 14:07 |
19:57:49.379 : Info:Motorized bed leveling repetition 1 19:57:49.383 : Info:leveling z1 and z2, iteration 1 19:57:59.645 : Z-probe:3.70 X:0.00 Y:60.00 19:58:10.927 : Z-probe:5.45 X:270.00 Y:60.00 19:58:21.832 : Z-probe:2.20 X:120.00 Y:300.00 19:58:22.250 : Transformation matrix: 0.999979 0.000061 -0.006472 0.000000 0.999955 0.009479 0.006472 -0.009479 0.999934
20:01:55.762 : Info:Motorized bed leveling repetition 2 20:01:55.766 : Info:leveling z1 and z2, iteration 1 20:02:04.836 : Z-probe:2.49 X:0.00 Y:60.00 20:02:14.007 : Z-probe:2.52 X:270.00 Y:60.00 20:02:23.561 : Z-probe:2.49 X:120.00 Y:300.00 20:02:24.114 : Info:no more leveling necessary, bed is flat 20:02:24.119 : Info:motorized bed leveling completed succesfully
Re: Höhe des Druckbett justieren 08. November 2015 15:37 |
Re: Höhe des Druckbett justieren 08. November 2015 15:43 |
Re: Höhe des Druckbett justieren 17. December 2015 16:23 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 23 |
Re: Höhe des Druckbett justieren 17. December 2015 18:39 |
Re: Höhe des Druckbett justieren 22. December 2015 11:56 |
Re: Höhe des Druckbett justieren 23. December 2015 03:10 |
Re: Höhe des Druckbett justieren 23. December 2015 03:51 |
#define FEATURE_TWO_ZSTEPPER 1 #define Z2_STEP_PIN ORIG_E2_STEP_PIN #define Z2_DIR_PIN ORIG_E2_DIR_PIN #define Z2_ENABLE_PIN ORIG_E2_ENABLE_PIN #define FEATURE_THREE_ZSTEPPER 1 #define Z3_STEP_PIN ORIG_E3_STEP_PIN #define Z3_DIR_PIN ORIG_E3_DIR_PIN #define Z3_ENABLE_PIN ORIG_E3_ENABLE_PIN
//AUX1 Pins, added to use stepperexpander #define ORIG_E2_STEP_PIN 64 #define ORIG_E2_DIR_PIN 59 #define ORIG_E2_ENABLE_PIN 44 #define ORIG_E3_STEP_PIN 40 #define ORIG_E3_DIR_PIN 63 #define ORIG_E3_ENABLE_PIN 42 //AUX1 Pins end
Re: Höhe des Druckbett justieren 23. December 2015 04:12 |
Re: Höhe des Druckbett justieren 23. December 2015 04:53 |
Boui3D
Da Du anscheindend mit Dir alleine reden möchtest und sich die Themen überschneiden, bin ich raus.
Schöne Tage noch
Re: Höhe des Druckbett justieren 23. December 2015 06:35 |
Re: Höhe des Druckbett justieren 23. December 2015 07:03 |
Boui3D
Ok, dann hab ich das falsch verstanden. Sorry
Aber macht es wirklich Sinn, diese Version noch zu nehmen?
In meinen Augen nicht, denn das aktuelle Repetier unterstützt nun ja mehrere Motoren auf Z und Dualextruder sowieso.
Es macht also mehr Sinn die G33 Sache auf das aktuelle 0.92.7 anzupassen, oder.
Schön wäre es, wenn Repetier diese einfach einbauen würde, meinetwegen per Haken zuwählbar. Mir ist völlig unklar, warum die Anfrage völlig ignoriert wird.
Die Funktion ist genial und fertig.
Andreas
Re: Höhe des Druckbett justieren 23. December 2015 07:09 |
aber beim nivellieren des Bettes Fährt er dann genau verkehrt herum.
Also ist zB Z2 zu hoch, dreht er es dann noch höher
Re: Höhe des Druckbett justieren 23. December 2015 07:19 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 89 |
Boui3D
Re: Höhe des Druckbett justieren 23. December 2015 07:32 |
Re: Höhe des Druckbett justieren 23. December 2015 07:40 |
Re: Höhe des Druckbett justieren 23. December 2015 07:46 |
Re: Höhe des Druckbett justieren 23. December 2015 08:48 |
Boui3D
Weißt Du wie lange das eingereicht und ohne Rückmeldung vor sich hinschlummert?
Mhmmm, in Programmierkreisen scheinen Wochen das zu sein, was bei Normalos Tage sind.
Re: Höhe des Druckbett justieren 23. December 2015 08:51 |
Boui3D
Ähm, ganz übersehen. Den Fehler hatte ich auch und er hatte es durch Tausch schon entfernt. siehe Beiträge oben.
Re: Höhe des Druckbett justieren 23. December 2015 11:08 |
gfunk
Bin in einer IT Firma, wir rechnen in Kalenderwochen bzw Monaten und bei uns wird jeder für die Arbeit bezahlt
Re: Höhe des Druckbett justieren 24. December 2015 02:55 |
Re: Höhe des Druckbett justieren 24. December 2015 04:25 |
Re: Höhe des Druckbett justieren 24. December 2015 06:10 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 6 |
Re: Höhe des Druckbett justieren 24. December 2015 06:44 |
Re: Höhe des Druckbett justieren 25. December 2015 15:42 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 41 |
Re: Höhe des Druckbett justieren 25. December 2015 15:54 |
