Re: Network connection December 26, 2013 04:18PM |
Re: Network connection December 26, 2013 04:39PM |
Re: Network connection December 26, 2013 05:47PM |
Re: Network connection December 26, 2013 07:47PM |
Re: Network connection December 27, 2013 06:10AM |
Just to confirm, I always see the controls for half a second before it switches to the login page. Logging in is still hit & miss, but hit enough to print off my first few objects yestderday!Quote
dc42
When I connect via Ethernet, I always see the control page briefly before the login page appears. So I think this is normal behaviour.
Re: Network connection December 27, 2013 10:32AM |
Radian
dc42
Re: Network connection December 27, 2013 05:34PM |
Re: Network connection December 27, 2013 06:12PM |
Re: Network connection December 28, 2013 04:34AM |
Re: Network connection December 28, 2013 05:05AM |
Re: Network connection December 28, 2013 05:32AM |
Re: Network connection December 28, 2013 09:09AM |
Re: Network connection December 28, 2013 09:41AM |
Re: Network connection December 28, 2013 03:41PM |
Re: Network connection December 28, 2013 04:07PM |
Is JP9 linked with a jumper?Quote
markbee
I just tested my replacement board with the 5 volt derived from the PSU. The webinterface now seems to work ok. The control page appears for a short while, then the login page. But this time I can log in and see the control and the other pages. I did not print or made other tests yet.
I had first to solder a three pin header to the pads marked J20 on the Duet board. For getting the 5 volt supply to work both left pins of the power pcb (K1) had to be connected to GND on J20 on the Duet board and the right pin of the three header row (K1, power pcb) to 5V_IN of J20.
So it's obvious the step-down regulator (A4403) is again not working on my replacement board. Resistors (R60, R62) are soldered as silkscreen indicates...
Markus
Re: Network connection December 28, 2013 04:15PM |
