Improving the proximity sensor - SUCCESS! December 22, 2013 08:28AM |
Re: Improving the proximity sensor December 22, 2013 08:43AM |
Re: Improving the proximity sensor December 22, 2013 09:27AM |
Re: Improving the proximity sensor - SUCCESS! December 26, 2013 04:17AM |
Re: Improving the proximity sensor - SUCCESS! December 26, 2013 07:18AM |
Re: Improving the proximity sensor - SUCCESS! December 26, 2013 07:44AM |
Re: Improving the proximity sensor - SUCCESS! December 26, 2013 07:57AM |
Re: Improving the proximity sensor - SUCCESS! December 26, 2013 08:08AM |
Re: Improving the proximity sensor - SUCCESS! December 26, 2013 09:22AM |
Re: Improving the proximity sensor - SUCCESS! December 26, 2013 12:37PM |
Re: Improving the proximity sensor - SUCCESS! December 26, 2013 03:04PM |
Re: Improving the proximity sensor - SUCCESS! December 26, 2013 03:13PM |
Re: Improving the proximity sensor - SUCCESS! December 26, 2013 04:28PM |
Re: Improving the proximity sensor - SUCCESS! December 26, 2013 04:50PM |
Re: Improving the proximity sensor - SUCCESS! December 27, 2013 07:30AM |
Re: Improving the proximity sensor - SUCCESS! December 27, 2013 08:21AM |
Re: Improving the proximity sensor - SUCCESS! December 27, 2013 10:06AM |
Re: Improving the proximity sensor - SUCCESS! December 27, 2013 10:51AM |
chriscain
You could use the FAN0 output on the Duet
it's connected to the PWM o/p pin with a mosfet and not used on the Ormerod as the fan is on all the time.
would need a higher resistor as it's on the 12v supply.
Re: Improving the proximity sensor - SUCCESS! December 27, 2013 11:07AM |
Re: Improving the proximity sensor - SUCCESS! December 27, 2013 01:02PM |
Re: Improving the proximity sensor - SUCCESS! December 27, 2013 03:28PM |
Re: Improving the proximity sensor - SUCCESS! December 27, 2013 04:39PM |
Rory166
Yes I see that using FanO requires 12V, although I assume it would work with a lower voltage than it is intended for(all rails share the same common?).
Rory166
The point about the sunlight is that the output of the photo transistor needs to be kept low in case it is exposed to direct sunlight which might cause a huge increase in output, hopefully one might still pickup the modulation even over a much larger ambient signal. The price you pay is lower resolution. I suspect that if the sensor gave a maximum of 100 at 1.5mm sensor seperation this might be good because even if the ambient pushed the signal up to 900 then the sensor would still just work.( using the assumption that the phototransistor is linear which it probaly isn't) I am assuming the ADC has a 0 - 1000 range.
Rory166
Alternatively just tell the users not to try and print ouside on hot sunny days.
Re: Improving the proximity sensor - SUCCESS! January 03, 2014 08:12AM |
Re: Improving the proximity sensor - SUCCESS! January 03, 2014 02:14PM |
Re: Improving the proximity sensor - SUCCESS! January 03, 2014 04:46PM |
chriscain
To have a baseline for the sensor before any mods I wrote a quick script to check the bed level + sensor readings
Re: Improving the proximity sensor - SUCCESS! January 03, 2014 06:28PM |
White Tape VS Silver Tape January 04, 2014 04:25PM |
Re: White Tape VS Silver Tape January 04, 2014 04:34PM |
Re: Improving the proximity sensor - SUCCESS! January 05, 2014 07:41AM |
ser.write('M111 S0\n')
