SD Card issues December 31, 2013 02:33AM |
Re: SD Card issues December 31, 2013 03:51AM |
Re: SD Card issues January 05, 2014 03:57PM |
Re: SD Card issues January 05, 2014 11:29PM |
RepRapFirmware is up and running. serial: M503 ; RepRapPro Ormerod ; Standard configuration G Codes M111 S1; Debug on M550 POrmerod; Set the machine's name M551 Preprap; Set the password M552 P192.168.1.14; Set the IP address M553 P255.255.255.0; Set netmask M554 P192.168.1.1; Set the gateway M555 P2; Emulate Marlin USB output M92 E420; Set extruder steps/mm G21 ; Work in mm G90 ; Absolute positioning M83 ; Extrusions relative M558 P1 ; Turn Z Probe on G31 Z0.5 P500 ; Set Z probe height and threshold M906 X800 Y800 Z800 E800 ; Motor currents (mA) T0 ; Select extruder 0 ok Class GCodes spinning. Class Webserver spinning. Class Move spinning. Class Platform spinning. Class Heat spinning.
RepRapFirmware is up and running. Can't open 0:/sys/config.g to read from. Error code: 1 Configuration file not found
Re: SD Card issues January 06, 2014 01:31AM |
Error: invalid M Code: M115
RepRapFirmware is up and running. serial: M115 FIRMWARE_NAME:RepRapFirmware FIRMWARE_VERSION:0.50 ELECTRONICSuet DATE:2013-12-30 ok serial: M503 ; RepRapPro Ormerod ; Standard configuration G Codes M111 S1; Debug on M550 POrmerod; Set the machine's name M551 Preprap; Set the password M552 P192.168.1.14; Set the IP address M553 P255.255.255.0; Set netmask M554 P192.168.1.1; Set the gateway M555 P2; Emulate Marlin USB output M92 E420; Set extruder steps/mm G21 ; Work in mm G90 ; Absolute positioning M83 ; Extrusions relative M558 P1 ; Turn Z Probe on G31 Z0.5 P500 ; Set Z probe height and threshold M906 X800 Y800 Z800 E800 ; Motor currents (mA) T0 ; Select extruder 0 ok Class GCodes spinning. Class Webserver spinning. Class Move spinning. Class Platform spinning. Class Heat spinning.
