Re: Fan backwash problem - new parts to fix January 09, 2014 07:05AM |
dc42
Andy, are you sure you have put the correct files in the zip? File fan_deflector_v4.scad contains this:
use <fan_deflector_v2_aerofoil.scad>
but the actual file supplied is fan_deflector_v4_aerofoil.scad
Re: Fan backwash problem - new parts to fix January 12, 2014 12:38PM |
Re: Fan backwash problem - new parts to fix January 13, 2014 04:28AM |
Re: Fan backwash problem - new parts to fix January 13, 2014 06:37AM |
Re: Fan backwash problem - new parts to fix January 13, 2014 07:12AM |
rayhicks
I'll be printing one of these excellent mods asap, but since Markus pointed out the problem I've been using a much lower-tech solution (which has held up for a few hundred grams of ABS and is ultra-slimline). I applied a strip of Kapton tape across the lower part of the fan pictured printing a threadless ballscrew in ABS on Marley KS10 bed coating (there's some motion blur):
[attachment 24661 backwashmod.jpg]
Re: Fan backwash problem - new parts to fix February 09, 2014 07:38AM |
Re: Fan backwash problem - new parts to fix February 09, 2014 07:20PM |
Re: Fan backwash problem - new parts to fix February 10, 2014 08:15AM |
Re: Fan backwash problem - new parts to fix February 10, 2014 08:25AM |
Re: Fan backwash problem - new parts to fix August 10, 2014 05:26AM |
Re: Fan backwash problem - new parts to fix January 03, 2016 05:37AM |
Re: Fan backwash problem - new parts to fix January 03, 2016 05:43AM |
Re: Fan backwash problem - new parts to fix January 03, 2016 06:05AM |
Re: Fan backwash problem - new parts to fix July 25, 2017 07:49AM |
Treito
As I have another nozzle I would have the 4 screws. I needed 4 screws to securely connet the two pieces which hold the nozzle together. That would be not a big deal. I do not like the countersunk screw design otherwise I would have taken your design.
I guess I will first try this one:
[www.thingiverse.com]
The first design I posted above looks interesting because it transfers the air completely up, but maybe it blocks also too much.
Re: Fan backwash problem - new parts to fix July 29, 2017 08:07PM |
Re: Fan backwash problem - new parts to fix July 31, 2017 07:47AM |
Peterdl
The fan should BLOW out of the 3 holes by the nozzle. The fan housing should have 2 arrows on it somewhere. One arrow shows the direction of the blades and the other shows the direction of the airflow. The airflow arrow should be pointing TO the heatsink.
Pete.
