Ethernet connection problems: possible solution [UPDATED] January 03, 2014 03:53PM |
Re: Ethernet connection problems: possible solution January 03, 2014 04:16PM |
Re: Ethernet connection problems: possible solution January 03, 2014 04:28PM |
Re: Ethernet connection problems: possible solution January 03, 2014 04:34PM |
Re: Ethernet connection problems: possible solution January 03, 2014 04:44PM |
Re: Ethernet connection problems: possible solution January 03, 2014 05:29PM |
dsred294
I normally had debug switched off on the standard firmware.
Re: Ethernet connection problems: possible solution January 03, 2014 06:19PM |
Re: Ethernet connection problems: possible solution January 03, 2014 06:21PM |
Re: Ethernet connection problems: possible solution January 03, 2014 06:27PM |
Re: Ethernet connection problems: possible solution January 03, 2014 06:51PM |
Re: Ethernet connection problems: possible solution January 03, 2014 07:34PM |
Re: Ethernet connection problems: possible solution [UPDATED] January 04, 2014 08:16AM |
Re: Ethernet connection problems: possible solution [UPDATED] January 04, 2014 09:17AM |
Re: Ethernet connection problems: possible solution [UPDATED] January 04, 2014 10:44AM |
Re: Ethernet connection problems: possible solution [UPDATED] January 04, 2014 11:10AM |
Re: Ethernet connection problems: possible solution [UPDATED] January 04, 2014 11:14AM |
Re: Ethernet connection problems: possible solution [UPDATED] January 04, 2014 11:21AM |
Re: Ethernet connection problems: possible solution [UPDATED] January 04, 2014 11:23AM |
Re: Ethernet connection problems: possible solution [UPDATED] January 04, 2014 12:17PM |
dc42
Sure! Please tell us how will you be connecting the printer: direct to your router, or to a computer that is wirelessly connected to your router, or some other way?
Also go to a command shell, run ipconfig, and post the results.
Re: Ethernet connection problems: possible solution [UPDATED] January 04, 2014 12:38PM |
Re: Ethernet connection problems: possible solution [UPDATED] January 04, 2014 06:27PM |
Re: Ethernet connection problems: possible solution [UPDATED] January 04, 2014 06:35PM |
Re: Ethernet connection problems: possible solution [UPDATED] January 05, 2014 07:49AM |
Re: Ethernet connection problems: possible solution [UPDATED] January 05, 2014 12:26PM |
dieterzar
On my one it only worked once reset with the network cable plugged into it, if I plug it in after a reset, no go... It otherwise logs in fine and does everything fine via LAN. No issues.
Re: Ethernet connection problems: possible solution [UPDATED] January 05, 2014 03:40PM |
Re: Ethernet connection problems: possible solution [UPDATED] January 05, 2014 03:51PM |
Re: Ethernet connection problems: possible solution [UPDATED] January 05, 2014 03:56PM |
Re: Ethernet connection problems: possible solution [UPDATED] January 05, 2014 04:04PM |
Re: Ethernet connection problems: possible solution [UPDATED] January 05, 2014 04:05PM |
Re: Ethernet connection problems: possible solution [UPDATED] January 05, 2014 04:07PM |
dc42
Hitting M503 in Pronterface (or Arduino serial monitor) gives you the contents of the config.g file, not the current settings. However, unless you have the problem that I and some others had (config.g not getting run because SD card supplied was too slow), then unless you have manually changed the settings since config.g was run. those should be the connection details that the Ormerod is using.
