Issue with Pronterface... January 06, 2014 01:46AM |
Re: Issue with Pronterface... January 06, 2014 05:04AM |
Re: Issue with Pronterface... January 06, 2014 05:09AM |
Re: Issue with Pronterface... January 06, 2014 06:19AM |
dc42
Paul, I had the same problem with the original card supplied with the kit (config.g not running, so Pronterface thinks the Duet is offline). I bought a Maplin 4Gb Class 10 card, and I have had no problems since I used that instead.
Re: Issue with Pronterface... January 06, 2014 06:33AM |
Re: Issue with Pronterface... January 06, 2014 06:35AM |
Re: Issue with Pronterface... January 06, 2014 09:38AM |
Re: Issue with Pronterface... January 06, 2014 09:57AM |
Re: Issue with Pronterface... January 06, 2014 10:57AM |
TMD_RS436
Now its working, seems that I will also need to buy a new SD Card along with a longer USB Cable.
Paul
Re: Issue with Pronterface... January 06, 2014 11:02AM |
ormerod168
TMD_RS436
Paul
USB Cable advice: get a more flexible one than the one supplied, it will put less train on the board connection, I use a Amazon Kindle Reader cable, very flexible, L=1780mm D=3mm
Erik
Re: Issue with Pronterface... January 06, 2014 04:07PM |
Re: Issue with Pronterface... January 06, 2014 04:54PM |
Re: Issue with Pronterface... January 08, 2014 08:54AM |
luposlip
Noone found another reason for this issue? I'm seing the same.
It worked just fine. Then I updated the config.g with new Z-axis calibration values and re-inserted the SD card (printer turned off).
I see this issue every time I turn on my printer now. Have tried to format the card and copy the SD-image content onto it again. Nothing seems to work.
Best,
Henrik
