Minimal size of print? January 10, 2014 09:25AM |
Re: Minimal size of print? January 10, 2014 10:34AM |
Re: Minimal size of print? January 10, 2014 10:54AM |
Re: Minimal size of print? January 10, 2014 11:19AM |
rayhicks
Hi Paul,
I've just started printing your gcode file, and all seems fine using ABS for the first few layers (I've commented out your temperature settings) - looks like you need to slice it with some support material though, the tab that starts printing on layer 16 drops to the bed
rayhicks
You might need to raise your bed temperature to get the PLA to stick properly and make sure the kapton is clean (I'm printing onto kapton with my ABS, but I use PVC pipe welding cement when I use PLA, you could try some of this if you have some lying around - remove the kapton and brush the cement on then print when its dry),
Ray
Re: Minimal size of print? January 10, 2014 11:34AM |
rayhicks
Here's the finished print on the bed - top view [attachment 24447 yopview.jpg]
rayhicks
and side view showing sagging loops (needs support)[attachment 24448 sideview.jpg]
rayhicks
it also curled a little toward the x motor, but it did stay on!
rayhicks
It might be worth adding a brim in slic3r to widen the attachment surface if all else fails,
Re: Minimal size of print? January 10, 2014 12:45PM |
Re: Minimal size of print? January 10, 2014 04:09PM |
Re: Minimal size of print? January 11, 2014 11:00AM |
Re: Minimal size of print? January 11, 2014 11:34AM |
TMD_RS436
One thing that I have noticed is that I have to re-setup Z axis along with the Bed Plane Compensation every day and also sometimes before every print, this is becoming to be annoying, but its reducing failed print jobs.
Re: Minimal size of print? January 11, 2014 11:50AM |
dc42
TMD_RS436
I had this too. I think it was due to the back corners of the MDF bed support sagging. I've replaced mine with aluminium, see here. There are other other solutions in the post following that one, and here.
G30 P0 X60 Y0 Z0 ; back left difference. G30 P1 X60 Y180 Z0.1 ; back right difference. G30 P2 X180 Y180 Z3.0 ; front right difference. G30 P3 X180 Y40 Z2.3 S ; front left differnce.
Re: Minimal size of print? January 11, 2014 12:42PM |
Re: Minimal size of print? January 11, 2014 12:53PM |
dc42
I'm now using 3-point bed setting instead of 4-point. This disables the second-order bed compensation, which as far as I can see should not be needed if the glass bed is flat and the two y-rods are truly parallel, because the X and Y axes are independent. The 3rd point is in the front centre, near the levelling screw.
There does appear to be a very slight convex curvature at the front of my glass plate, although it's very small. I may try a piece of 4mm float glass when I want to print large pieces.
Re: Minimal size of print? January 11, 2014 01:06PM |
TMD_RS436
Hello dc
dc42
Yeah I was going to do the same by using a three sided bead support at first, but where I have been very unlucky as late I would probably crack or break one of the corners off, so I am thinking of the rectangle with corner angle supports just on the safe side.
I think the glass + alu heat spreader + heated pcb combo would be very hard to break. I'm still using the front corner screws to hold the heat spreader to the heater pcb. Here is a photo of my setup.
Re: Minimal size of print? January 11, 2014 01:16PM |
dc42
TMD_RS436
Hello dc
dc42
Re: Minimal size of print? January 11, 2014 02:14PM |
Re: Minimal size of print? January 11, 2014 03:37PM |
TMD_RS436
But yeah yours looks nice now, how stiff was the aluminium once you cut out the un needed areas?
TMD_RS436
Also how did you get it to print across the gap on the top without and support?
Re: Minimal size of print? January 11, 2014 03:44PM |
droftarts
On my first printer...
(That picture was taken the day I got it working! May 2011, I think.)
Re: Minimal size of print? January 11, 2014 04:14PM |
I've still got MOST of it... but I did take it apart, as I needed the rods and linear bearings for my second printer! I will rebuild it one day, as it was one of the few examples of a 1X2 (as it was called - it was supposed to be made from 1" x 2" timber) - [reprap.org]Quote
dc42
I love the wooden construction! I hope you've still got it, it may be valuable as an antique some day.
