Still warping ... January 13, 2014 03:11PM |
Re: Still warping ... January 13, 2014 03:41PM |
Re: Still warping ... January 13, 2014 04:27PM |
Re: Still warping ... January 13, 2014 04:39PM |
Re: Still warping ... January 13, 2014 04:47PM |
it's the "brim" option (skirt prints a ring around, brim prints a plate under and around- but you then have to separate it after the print)Quote
treth
Their software prints a base layer that sticks to this and in our case exceeded the base of the real 3D print by approx 5mm and was about 1mm thick.
Re: Still warping ... January 13, 2014 04:52PM |
Re: Still warping ... January 13, 2014 05:14PM |
Re: Still warping ... January 13, 2014 06:12PM |
rayhicks
Your Kapton looks a little fluffy - is it dust or is it a bit hacked up? I haven't had problems adhering to hacked up Kapton ,but I imagine dusty/fluffy Kapton wouldn't let the abs grip
What temperature measurer are you going for? I think Ian mentioned they use a pointing thermometer at rrp for the bed, I'm tempted to pop down to Maplin and pick one up soon so I can have a better idea of what my actual bed temp is. Next time I dismantle the hotend I'm going to drill a hole for a thermocouple probe in the heater block too
Cheers
Ray
Re: Still warping ... January 14, 2014 01:12PM |
Re: Still warping ... January 14, 2014 02:25PM |
I've got a vague plan to hook up a peristaltic pump and use water through the cooling block and dispense with the Fan (then look at putting an intentional print cooling fan on - I need to look into that more).
Re: Still warping ... January 14, 2014 02:36PM |
rayhicks
Maybe to high a temperature IS your problem then (on top of the conductive stuff of course)- according to dc42 the target temps should drop by around 10 after the firmware upgrade
Re: Still warping ... January 15, 2014 09:24AM |
Re: Still warping ... January 15, 2014 09:55AM |
Re: Still warping ... January 15, 2014 11:10AM |
Re: Still warping ... January 15, 2014 11:29AM |
Re: Still warping ... January 15, 2014 12:32PM |
Re: Still warping ... January 15, 2014 03:34PM |
Re: Still warping ... January 21, 2014 02:33PM |
Re: Still warping ... January 21, 2014 06:37PM |
Re: Still warping ... January 21, 2014 06:43PM |
Re: Still warping ... January 21, 2014 07:32PM |
Re: Still warping ... January 22, 2014 12:54PM |
Re: Still warping ... January 22, 2014 01:30PM |
Oh yes, I forgot we updated that part slightly. Only the first 200 came without the fins, I think. They are more an aid to holding up the roof while printing, than for the airflow.Quote
dmould
I noticed that the fan mount I printed from the github is different to the part supplied - it has dividers in the air channel that must also be cut away when doing that mod.
Re: Still warping ... January 22, 2014 01:57PM |
50:50 PVA/Water on glass February 04, 2014 09:18AM |
Re: 50:50 PVA/Water on glass February 04, 2014 10:52AM |
