Prerequisites for printing? January 20, 2014 04:51PM |
Re: Prerequisites for printing? January 20, 2014 06:41PM |
Re: Prerequisites for printing? January 20, 2014 07:53PM |
Re: Prerequisites for printing? January 21, 2014 03:35AM |
Re: Prerequisites for printing? January 21, 2014 05:08AM |
Re: Prerequisites for printing? January 21, 2014 05:20AM |
Re: Prerequisites for printing? January 21, 2014 05:32AM |
Re: Prerequisites for printing? January 21, 2014 12:34PM |
Re: Prerequisites for printing? January 21, 2014 12:36PM |
GregL
Just trying my first print - Ormaxis
Concerned that the extruder will sit chattering, when it should clearly be extruding along a long run.
I have to help it turn.
What to do?
Greg
Re: Prerequisites for printing? January 21, 2014 12:50PM |
GregL
What to do?
Greg
Re: Prerequisites for printing? January 21, 2014 05:25PM |
Re: Prerequisites for printing? January 22, 2014 05:06AM |
Re: Prerequisites for printing? January 22, 2014 05:16AM |
GregL
Maybe I need to run it at +5C over normal settings.
GregL
Bed seems rock solid at 21.7, but the extruder is erratic. Mostly 15.6, but it will randomly jump to 18.6, 12.3, 3.6, 8.4
What is going on there?
Re: Prerequisites for printing? January 23, 2014 10:25AM |
Re: Prerequisites for printing? January 23, 2014 10:54AM |
GregL
Still have the same problem on trying to print the Ormaxis - extruder stutters.
Although set at 205, the hot end was mostly around the 201.5 region.
Should I:
1. Set the hot end higher still
2. Increase the amps on the extruder motor (if so how?)
3. take the hot end apart and re-assemble
Greg
PS firmware was and still is 057a
Re: Prerequisites for printing? January 23, 2014 01:15PM |
Re: Prerequisites for printing? January 23, 2014 01:50PM |
Re: Prerequisites for printing? January 24, 2014 03:03AM |
Re: Prerequisites for printing? January 24, 2014 03:48AM |
GregL
I do have a problem with the Z gears: the rod movement is eccentric at the Z gear, and there is cyclic noise clearly associated with the rotation of the gear. I have also had quite a few inconsistencies when trying the bed levelling - ie go back to the first point to find its Z level has changed. How do I tackle those Z gears?
Greg
Re: Prerequisites for printing? January 24, 2014 08:06AM |
Re: Prerequisites for printing? January 24, 2014 10:25AM |
Re: Prerequisites for printing? January 24, 2014 11:46AM |
Re: Prerequisites for printing? January 25, 2014 06:15AM |
Re: Prerequisites for printing? January 25, 2014 09:19AM |
Re: Prerequisites for printing? February 02, 2014 07:02AM |
Re: Prerequisites for printing? February 02, 2014 01:34PM |
Re: Prerequisites for printing? February 02, 2014 04:05PM |
GregL
...and I would like suggestions on a suitable demonstration object which can be printed at Ormerod's maximum accuracy.
Greg
