RF Noise problem
January 21, 2014 06:30AM
Just switch on Ormerod, and kids shouting at me that TV suddenly turns snowy badly, I try to switch on and off my antenna booster, check on RF cables and try to fine tune my TV but can't correct the badly snowy image on the screen , and also white noise from TV's speaker. I gave up and think I might need a new antenna or TV.
After I turned off Ormerod to take out SD card for saving some of my G codes, the TV suddenly turns clear. I can't believe it and I turn on Ormerod again, and TV become snowy again !!
I clamp a few ferrite filter on the power supply output and input without any improvement.
Swap to 12V 30A industrial power supply and everything goes fine !!!!
EDIT: Mine was Alpine 600W
Ew
Edited 1 time(s). Last edit at 01/21/2014 06:43AM by tru168.
Re: RF Noise problem
January 21, 2014 08:49AM
Get a satellite subscription! What country are you in? UK terrestrial TV is all digital these days, so RF noise will either not affect it or kill the reception just about completely.
January 21, 2014 09:11AM
I'm in Malaysia , no digital TV yet :-(
January 21, 2014 09:40AM
tru168
Gosh, the Omerod certainly gets around! Digital TV is a mixed blessing - too much commercial temptation to squeeze in more channels by over-compressing to reduce the bit-rate. Plus the general rule is that the more channels you have, the lower the quality of each. The RF noise your Omerod makes is probably more interesting to watch than most of the channels here!
January 21, 2014 10:40AM
Dmould:
Yeah, Still using analog here, I even built Vacuum Tube amplifier for my Hi Fi system ;-)
January 21, 2014 11:15AM
Hi.... I won't say that the Ormerod isn't causing your problem but it's unlikely. Here's a possible solution to what ever it is that is causing it.
RF Braid Breaker
Another design
But the easiest and cheapest is the two loops of coax cable tied together (See the picture).
Basically you make two loops of TV coax. Bare the ends to expose the center core. Nibble off a section of the outer insulation
about 2" from the end, then solder the center core to outer braid you've just bared back so it makes a loop.
Use a bit of tape to cover the connection. Then make another loop the same. Then just tape the two loops together.
Your TV signal should be clear as a bell then (hopefully). The two loops form a transformer that allows the TV signal to cross over, but insulates
the TV coax from a direct connection. Then connect it between the TV Ariel socket and the Ariel lead. (You might have to try it at the TV, then the amplifier to see where the interferance is getting in.
The problem you describe with your TV used to be very common due to CB radio interference and the like.
Hope that helps.
Kim
open | download - braid breaker.jpg (15.1 KB)
January 21, 2014 11:58AM
As a Ham Radio Operator for years, I should think of that before you mentioned it. Thanks !
Ew
January 21, 2014 12:43PM
hihihihi
Used to be G7JYT
Now M0GIO....
Nice to meet you Brother...
QRT
smileys with beer
Edited 1 time(s). Last edit at 01/21/2014 12:45PM by KimBrown.
January 21, 2014 09:53PM
See? Repraper's usually share common interest !
73!
9W2ECG
January 22, 2014 02:00PM
tru168
73!
9W2ECG
Going back quite a few years - I used to be ZE1FY (later Z21FY). Then Z21FY/MM for 5 years.
Dave
(#106)
January 22, 2014 03:48PM
Hello Fellow Radio Users smiling smiley
Well I got to the 2E0 was contemplating on going the full hog and get the M0 but wasn't worth while for me due to restrictions where I am located so I won't be able to run the full 400W (if needed) also the extra band or two you get with a M0 didn't really interest me much also wouldn't be able to put up the antennas for half the bands anyway.
Also 50W (max) is fine for my needs at the moment, and I get to make stuff also smiling smiley
Paul
RS Ormerod No 436
January 22, 2014 09:37PM
400 W thats thats a lot of power ! I'm QRP guy and my DIY rig will not more than 5W, FM or SSB.
need big antenna though..
January 22, 2014 09:52PM
tru168
Well I am using an ICOM IC-746 with the power turned to the minimum (prob about 1 W) and all the people that I talk to can hear me smiling smiley
Paul
RS Ormerod No 436
January 23, 2014 10:06AM
If you want to make a rig for frequencies higher than UHF, you can make quite a powerful transmitter from the parts in a microwave oven ...
Dave
January 23, 2014 11:40AM
It's nice to see like minded people nattering.... How did the TV interference problem go? fixed??
I still have my Rigs, in a box safe.... I now live surrounded by houses that are higher than me, so daren't go on air.... But one day.
I miss using my Kenwood, but I use the 100Amp 12V power supply allot for different things.
Wish I had this print back in the days where I was building stuff.. I used to hate cutting the holes out for meters etc, now we can just print them... spinning smiley sticking its tongue out
I might setup a Maritime mobile shack here for the help of it during the summer. It's too cold to go messing with ariels at the moment.
January 23, 2014 09:47PM
Hi
Yes, problem fixed by just added a line filter on my power supply :-)
