Cura 14.01 January 26, 2014 04:41AM |
Re: Cura 14.01 January 26, 2014 06:16AM |
Re: Cura 14.01 January 26, 2014 06:44AM |
Re: Cura 14.01 January 26, 2014 01:44PM |
Re: Cura 14.01 January 27, 2014 12:37PM |
Re: Cura 14.01 January 29, 2014 04:54AM |
Re: Cura 14.01 January 29, 2014 03:41PM |
Re: Cura 14.01 January 29, 2014 04:32PM |
Re: Cura 14.01 January 30, 2014 03:51AM |
Re: Cura 14.01 January 30, 2014 11:56AM |
Re: Cura 14.01 February 01, 2014 11:01AM |
Re: Cura 14.01 February 01, 2014 11:33AM |
Re: Cura 14.01 February 01, 2014 12:47PM |
Re: Cura 14.01 February 01, 2014 01:32PM |
Re: Cura 14.01 February 01, 2014 01:49PM |
Re: Cura 14.01 February 02, 2014 05:44AM |
Re: Cura 14.01 February 03, 2014 03:02PM |
Re: Cura 14.01 February 03, 2014 03:39PM |
Re: Cura 14.01 February 04, 2014 02:38AM |
Re: Cura 14.01 February 06, 2014 04:35AM |
Re: Cura 14.01 February 11, 2014 01:47PM |
Cash
i found out it is not only the the Z-command that will be ignored. It looks like only the last 2 or 3 move commands/lines from the attached file are executed.
I had to add more and more lines, that the Ormerod does anything....
Re: Cura 14.01 February 11, 2014 01:56PM |
Re: Cura 14.01 February 11, 2014 02:09PM |
Re: Cura 14.01 February 11, 2014 02:17PM |
Re: Cura 14.01 February 11, 2014 02:35PM |
auser
I too have the problem that sometimes cura prints start "mid-air". this is using 57l from dc42 (thanks again for the great FW improvements).
What I did find out, is that to transfer cura-g-code i have to remove the last line which is a comment containing the cura-profile.
so any hints on how to avoid "air prints" AND how to presuade cura to not save the profile into cura-generated g-code is very welcome ;-)
Re: Cura 14.01 February 11, 2014 03:56PM |
Re: Cura 14.01 February 11, 2014 05:11PM |
Re: Cura 14.01 February 11, 2014 05:29PM |
Re: Cura 14.01 February 11, 2014 06:02PM |
Cash
Ok, i did it! Here is the first version, some cura parameters (like speed) could be optimized surely but it is working pretty well.
Please replace the corresponding 2 files in your cura program folder (programs/cura and programs/cura/plugins) with the attached files! And don't forget to enable the plugin after loading the object, or your slices view will be scrambled and your generated g-code file will not work.
I have tested this only with Cura version 13.12, but i think it should work also with newer versions!
Good luck!
Frank
Edit: Please check the temperatures before you print, i've set the hot end to 210C! I think a lower temperature should be also good for PLA printing!
Edit2: As machine i used Reprap Mendel and changed print sizes to 200mm, all other is default
defaults write com.apple.finder AppleShowAllFiles TRUE killall Finderfor the cura folder to become visible - you can then copy and paste the files into the target directories as normal (in my install, the /plugins folder didn't exist so I had to make it first).
Re: Cura 14.01 February 12, 2014 04:09AM |
