Re: Rebuilt the bottom Half January 28, 2014 04:19PM |
Re: Rebuilt the bottom Half January 28, 2014 04:38PM |
johneato
Paul
Yes its an early board, I need to sort it. A bit reluctant to do it at the moment as the system is very stable, none of the freezing I have read about on other threads.
John
Re: Rebuilt the bottom Half January 28, 2014 04:41PM |
PaulHam
Thanks John, that's cleared it up for me!
Perhaps ill give it a go in the future!
I see that you have had to bend the pin for the ir sensor too, I have a feeling mine will snap off !
Re: Rebuilt the bottom Half January 28, 2014 05:01PM |
Yeah feels like overkill, a big connector for one pin.Quote
TMD_RS436
PaulHam
Yeah I thought the same, I am so tempted in buying a 50pin IDC plug and connect that wire to pin 33 (I.e. the bent pin)
Paul
Re: Rebuilt the bottom Half January 28, 2014 05:10PM |
TMD_RS436
PaulHam
Paul
Re: Rebuilt the bottom Half February 01, 2014 01:56PM |
johneato
....However I do like the idea of doing away with the aluminium. I don’t know if that is a good idea, I would be interested to hear other peoples opinion.
John
Re: Rebuilt the bottom Half February 01, 2014 03:12PM |
Re: Rebuilt the bottom Half February 01, 2014 05:02PM |
johneato
....I presume that the PCB is now bearing the weight of the glass and print. Have you done anything to reinforce the PCB corners.
..Before I throw the aluminium away have you tried it with ABS.
John
