ABS Ormerod parts February 03, 2014 05:19AM |
Re: ABS Ormerod parts February 03, 2014 05:41AM |
Re: ABS Ormerod parts February 03, 2014 05:55AM |
Re: ABS Ormerod parts February 03, 2014 06:19AM |
Re: ABS Ormerod parts February 03, 2014 11:09AM |
Re: ABS Ormerod parts February 03, 2014 11:12AM |
Re: ABS Ormerod parts February 03, 2014 11:22AM |
Re: ABS Ormerod parts February 03, 2014 11:44AM |
tru168
KevM :
4 parts that will fail fast once you print ABS : Fan Duct, Heat sink duct, nozzle mount and X carriage. the nozzle mount need to be printed a few more extra in PLA first because it might fail before you successfully print one complete ABS part. I tried 4 times without success, cause by our ambient temperature. if your country temperature reads far below mine then you will be safe to print ABS.
good luck.
Re: ABS Ormerod parts February 03, 2014 01:25PM |
Re: ABS Ormerod parts February 03, 2014 02:27PM |
Re: ABS Ormerod parts February 03, 2014 02:52PM |
KevM
Well I'm in the UK (Essex) so if I turn the heating off in here it's pretty damn cold
Has anyone discovered the ideal ambient for printing ABS ?
Re: ABS Ormerod parts February 03, 2014 03:53PM |
), with no problems. Ideally the air around the print should be still and warm (very warm) to minimise or slow down the contraction that can cause delamination of the higher layers, or warping of the bottom layers (particularly at edges and corners) - but moderate draughts around a comfortable room temp don't seem to cause problems for me (I did get some cracking on a 5 inch high print the other day). Under those conditions (room temp between 15 and 23 degrees C, the sensitive parts outlined above don't get past 40°C for me, the bracket maybe gets to 45, but I replaced that with acetal becasue the original was damaged by an accidental overheating of the hotend in December).|
Re: ABS Ormerod parts February 07, 2014 12:05PM |
Re: ABS Ormerod parts February 07, 2014 02:23PM |
Re: ABS Ormerod parts February 07, 2014 07:39PM |
