Modifications to printer February 05, 2014 10:11AM |
Re: Modifications to printer February 05, 2014 11:08AM |
Re: Modifications to printer February 05, 2014 11:33AM |
Re: Modifications to printer February 05, 2014 01:09PM |
Re: Modifications to printer February 05, 2014 01:30PM |
Re: Modifications to printer February 05, 2014 03:26PM |
Re: Modifications to printer February 05, 2014 04:24PM |
Re: Modifications to printer February 06, 2014 03:26AM |
Re: Modifications to printer February 06, 2014 04:27AM |
GregL
A 1Kg reel of filament is more like 1.18Kg. When (soon) we have three colours, we will have nearly 3.5Kg of reels - definitely not want that hanging off the Z axis
Greg
Re: Modifications to printer February 06, 2014 04:35AM |
Re: Modifications to printer February 06, 2014 05:13AM |
3djim
Hi.
I can successfully print at 0.12 layer heights consistently. The bed modifications along with zeroing the x and z axis with micro switches means I no longer have to adjust the bed at all and I don't have to use any compensation. The idea behind moving the extruder was to take any unnecessary weight off the x axis and to allow me to fit a piece of aluminium angle in the near future to further support the x axis.
Re: Modifications to printer February 06, 2014 05:53AM |
Re: Modifications to printer February 06, 2014 08:14PM |
Re: Modifications to printer February 07, 2014 03:59AM |
onno
That makes me wonder: would replacing the IR probe by a microswitch still allow for bed-level compensation? I would place the microswitch in roughly the same spot as the probe, but would (hopefully) get rid of the problems with the probe.
Re: Modifications to printer February 07, 2014 04:13AM |
Re: Modifications to printer February 07, 2014 06:49AM |
Re: Modifications to printer February 07, 2014 07:38AM |
Re: Modifications to printer February 07, 2014 08:18AM |
3djim
I have fitted micro switches to both the X and Z axis and as long as the bed is level and stable on the linear bearings there is no need to have compensation running. I have been using the micro switches for the past 2 weeks, printing every day and have had no compensation running. Setting the machine up correctly mechanically in the first instance is key. As for the z axis micro switch I have altered the homing config file so the X axis is at 2 mm when the Z axis homes this means that the nozzle is clear of the side of the table. I take the Z axis down so that it operates the micro switch at -0.1mm and then drives up to the zero point. No need for servos to drive the micro switch into and out of homing position.
