Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 26, 2014 08:59AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 26, 2014 09:04AM |
stevelup
dc42, could you please let me know where I can find a mechanical drawing of the ultrasonic transducer.
I'm going to design a mounting bracket for it, but could do with accurate dimensions.
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 26, 2014 09:05AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 26, 2014 10:00AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 26, 2014 02:21PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 26, 2014 06:54PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 27, 2014 09:18AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 27, 2014 11:47AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 27, 2014 11:54AM |
gammasistemi
In your hothend airduct there are only two holes for the airflow, but in the original ormerod part there are 3 holes.
When i tested Matt's solution, i had some issues when printing long parts or bridges over the y axis, this because the central hole is important to cool the PLA.
The same part printed with the original duct was better.
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 27, 2014 03:29PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 27, 2014 03:36PM |
Davek0974
Just printed the duct, might not fit it yet if it needs modifying
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 27, 2014 03:53PM |
dc42
Davek0974
You don't have to use the one-piece duct with my sensor board, because johneato has kindly provided a variation on the standard 2-piece duct to include mounting holes for the board.
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 27, 2014 04:01PM |
Davek0974
dc42
Davek0974
Ooh, nice, where would that be located please?
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 27, 2014 04:05PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 27, 2014 05:07PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 27, 2014 08:45PM |
DCQuote
DC42
The new files are in the usual place [github.com]. You may need to extend the x-homing tab a little further in the +x-direction so that the IR sensor sees it before the insulator stops against the z-nut trap. I put an oversized piece of white sticky label on top of mine.
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 28, 2014 10:02AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 28, 2014 02:37PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 28, 2014 02:43PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 30, 2014 06:15AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 30, 2014 06:25AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 30, 2014 06:42AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 30, 2014 07:13AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 30, 2014 11:49AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 30, 2014 02:29PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 30, 2014 03:29PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 30, 2014 03:44PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 30, 2014 04:01PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 30, 2014 04:27PM |
dc42
Hi MrCrispi, if you are getting 2000C with the thermistor disconnected, your H value is too far away from zero. Try H-35 or H-34 etc. until you get a -273 reading with thermistor disconnected.
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 30, 2014 04:36PM |
